Clicking/Cracking noise when I make full turns (like when parking)... ???
Old Dec 10, 2009 | 01:29 AM
  #31
garrickl's Avatar
garrickl is infamous around these parts
Drop Links were problem
I recently installed the PSS10 system with HR front and rear sway bars. The front sway bar was set at medium stiffness [middle hole]. Front drop links came with the PSS10 system. After experiencing similar noise the tech put the car on the hoist and the drop links were rubbing on the PSS10 strut housing .... he flat filed the area of the strut housing where rub could be seen and we reset the link to the soft position on the sway bar and all noise disappeared.
Old Dec 10, 2009 | 08:31 AM
  #32
landjet's Avatar
Originally Posted by Terminator
Did you get Bilstein ones with your PSS9's? Were they no good?
I no longer have PSS9's. I went to Motons and got the TRW drop links when I upgraded my sway bars.
When I had the PSS9's, they would make some spring noise at low speed but as soon as some aero force loaded the car, all spring noise went away.
Old Dec 10, 2009 | 11:38 AM
  #33
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
So how are the Motons? Much better?
Yes that's what I have; some spring twanging noises but only at low speeds and only sometimes when turning to full lock.
Old Dec 10, 2009 | 02:53 PM
  #34
landjet's Avatar
They make the same low speed noise but goes away at speed. The new suspension is way better, but that includes all the lower control arms, toe steer arms, upper control arms, bump steer front arms, sways, drop links, and locking plates. It's set up for the track but rides nice on the street when dialed back. A little stiffer but not bad. Great on track.
Old Dec 11, 2009 | 04:19 AM
  #35
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Mine makes this noise while turning the wheels at low speeds and while stopped. Mechanic checked it out a few months ago when it started and couldn't see any issues... said he thought it could be control arms. I have PSS10s on stiffest settings and H&R sways front and rear. But I had that suspension on and running for quite a while before I ever heard this noise..... hmmmm
Old Dec 11, 2009 | 04:53 AM
  #36
Terminator's Avatar
Yeah mine was dead quite too to begin with. But now I feel temperature makes a difference. +30C in the summer = no noise. +10C noises start and spring twangging starts. below 0 (-C) dashboard starts to sqweak anyway. . I just gave up. These cars grown and moan and that's all that's to it. Just like me getting old and creaky.
Old Dec 11, 2009 | 10:57 AM
  #37
landjet's Avatar
My tech says drop links loosen as they wear. That's why we went with the TRG's. Very stout with wider hiem joint material.
Old Feb 19, 2010 | 01:51 PM
  #38
langer911's Avatar
langer911 is infamous around these parts
Front strut mount and/ or bearing, probably.
Old May 31, 2011 | 04:09 PM
  #39
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
I have PSS10 with GT3 sways and tarret drop links...I had the noise too and it ended up ripping the brackets off my PSS10!
I am still trying to find a solution
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Zero911
Aug 24, 2015 06:51 PM
L.A.P.
Aug 23, 2015 11:48 PM
