Clicking/Cracking noise when I make full turns (like when parking)... ???
Old Jan 27, 2007 | 09:30 PM
ramone's Avatar
ramone is infamous around these parts
Whenever I make a full turn (turn the wheel all the way on the left or right side) and accelerate or reverse like when parking, the wheels making a clicking/cracking/popping noice and sort of resists the action....
Wtf is going on
Old Jan 27, 2007 | 09:31 PM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
Wheel bearings, probably.
Old Jan 27, 2007 | 11:20 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Check the black plastic inner fender liner for the front wheels. At the forward part of the liner closest to the ground, make sure there is no loose plastic or rubber. The rubber flap for aerodynamics sometimes pops out on my car and rubs the tire at full lock.
Old Jan 28, 2007 | 01:03 AM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
I had the same problem. I thought it was something else too.
Old Jan 28, 2007 | 01:07 AM
cjv's Avatar
cjv
Moderator
Did you replace your front sway bar?
Old Jan 28, 2007 | 03:11 AM
jrgatfh's Avatar
Awaiting Email Confirmation
jrgatfh has a spectacular aura aboutjrgatfh has a spectacular aura about
Sounds like droplinks........my car does the same thing too.....Its like a clicking/popping sound when you turn the wheel all the way while idling or moving very slow.
Do you have any aftermarket suspension components on your car? I.E. Swaybars like CJV said.
Old Jan 28, 2007 | 03:40 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Could be the Drop Links, The Nylon Ball has vitually no noise compared to a Spherical Bearing link, some makes are noisy!
Old Jan 28, 2007 | 06:14 PM
ramone's Avatar
This sounds like what it might be. but it makes popping noises and you can feel it in your car. isn't that manufacturing defect then ????
What can I do about it. because it feels like i'm damagin my car when i make those full turns...
EXACTLY !
no. my car is completely stock 03 turbo with 10K miles on it.
how did u solve it ?
Old Jan 28, 2007 | 06:55 PM
jrgatfh's Avatar
My car has aftermarket sway bars and coilovers and I'm told that when you turn the wheel and it reaches full lock there is too much pressure on the droplinks which causes it to pop, from what I hear its not bad for the car but it doesn't sound good either. I'm gettin new droplinks and the noise should go away but I know exactly what your talking about. I've never heard of this problem concerning a car that has a stock suspension so it might be something else, but then away maybe it can occur with a stock suspension, I'm still new to the P-car scene so I wouldnt no yet. If you are car savvy you should get under your car somehow and have a friend turn the wheel and see where its come from. If not take it too a shop I'm sure they will charge you very little to find out what it is, if they even charge you at all. Hopefully its nothing serious and you get it sorted out ASAP. Here is a link to a picture of what they should look similar too....Hope I helped you a little bit...
http://i21.ebayimg.com/02/i/04/71/df/b0_2.JPG
-Justin
Old Jan 28, 2007 | 08:47 PM
Member
...how did u solve it ?
It could have been designed better. The rubber flap has two tabs that fit into 2 slots on the fender liner. I just pop it back into place whenever it pops out. I asked a Porsche mechanic (certified) and he said not to waste money on a new part, just use some black silicone to keep it in place (which I have yet to do).
Old Jan 28, 2007 | 08:51 PM
ramone's Avatar
i bought my car second hand, i thought it was stock but who knows...and no i'm not car savy at all.
I will have this checked out ASAP.
Thanks for the insight guys
Old Jan 28, 2007 | 09:06 PM
iLLM3's Avatar
Tarek sounds like droplinks man!! Justin, yours are coming soon
Old Jan 29, 2007 | 12:00 PM
ebaker's Avatar
ebaker is infamous around these parts
Could be the bearing at the top of the strut that allows the strut to rotate when the wheels turn.
Old Apr 10, 2007 | 04:50 PM
evo911's Avatar
evo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the rough
ya mine does this too when i turn the wheel..... it has PSS9s on it i bought it 2nd hand has only 6400 mils on it too
Old Apr 10, 2007 | 07:51 PM
heavychevy's Avatar
Could be the brake ducts as well although your more likely to hear that in reverse.
