Help: Sound system problem
Old Feb 8, 2007 | 06:06 PM
No SubstiTTute's Avatar
No SubstiTTute is infamous around these parts
I have the standard Bose head unit with cassette and remote CD changer. My stereo turns on. I can activate the radio,tape and CD, and the display works. The CD changer works on command. But, I get no music from the speakers. All I get is a repetitive popping sound of about 2 beats per second coming from the Right front speaker and a rear speaker or speakers when the unit is powered up. The volume control has no effect on the volume of this sound. Any ideas? Thanks.
Old Feb 8, 2007 | 06:33 PM
PCJR's Avatar
PCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to behold
Most likely a bad amplifier. It is located under the hood and if you have the subwoofer, that amp is located next to the spare tire. Try pulling power to reset. If it does nothing, call the dealer to find out if they can swap it
out for you. It could also be a bad/shorted speaker which is causing the amplifer to go into a "protection" mode.
best of luck
Old Feb 8, 2007 | 06:42 PM
gtr's Avatar
gtr
gtr has a spectacular aura aboutgtr has a spectacular aura aboutgtr has a spectacular aura about
You should also check your amp fuse on the driverside kick panel also just in case it's blown.
Old Feb 8, 2007 | 06:45 PM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
sound system
I'd agree, sounds like an amp. Have the dealer fix under warrantee if still in force.
audipwr1
Sep 25, 2021 01:31 PM
Superaudiofreak
Jun 10, 2016 02:04 PM
pshep138
Sep 1, 2015 09:45 AM
orbelo
Aug 30, 2015 12:26 PM
