Garage door opener?
Old Mar 4, 2004 | 05:26 PM
TestnDoc's Avatar
Senior Member
TestnDoc is infamous around these parts
Garage door opener?
Has anyone installed a multi garage door opener, like a Homelink unit or sometheing similar? I dont want to have a bunch of gargae door remotes in my Pcar!! Thanks
Old Mar 4, 2004 | 06:45 PM
msindi's Avatar
Old Mar 4, 2004 | 06:51 PM
SANDOVAL's Avatar
Banned by Moderators
SANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura about
It is a DIY project... Thanks to Itzkirb
http://www.renntech.org/forums/index...wtopic=670&hl=
Old Mar 4, 2004 | 06:54 PM
SANDOVAL's Avatar
BTW it will cost you the switch $20 or so dollars & a garage door opener which you prob have. You need some fastners wire pliars and a soldering gun. It is a pretty simple DIY if you follow his instructions... Much cheaper then the $225
Old Mar 4, 2004 | 11:50 PM
Itzkirb's Avatar
Here you go
Garage Door Mod
I used the Targa roof switch, it looks just like a Garage door almost.
I believe since the switch is a rocker switch you CAN make it control multiple garage doors. Click one way for one door and the other way for the other door. It will require connecting the negative part of your openers into one wire and the positive wire from each would connect to the two side slots on the switch. If I had multiple garage doors I would have done it, but because I don't it's a bit more difficult to explain, but it can be done.
Old Mar 4, 2004 | 11:57 PM
SANDOVAL's Avatar
Do those come in shiny?
Old Mar 5, 2004 | 12:07 AM
Itzkirb's Avatar
Sandoval, I don't know if they come shiny. I have the powerlock switch still and that one is shiny.
Old Mar 6, 2004 | 03:52 PM
tme's Avatar
tme
tme is infamous around these parts
I ordered it from sharkworks and they hooked up 2 openers to 1 switch, each side opens a different door.
Old Jun 5, 2004 | 08:21 PM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
I am reviving this thread as I want to do this upgrade as well.
I can't seem to get sharkworks' website to come up. Are they still around?
Old Jun 5, 2004 | 09:20 PM
msindi's Avatar
Site is down and gone!! Wierd...
Try e-mailingthem directly at support@sharkworks.net and do let us know what they say...a friend wanted to order this
Old Jun 5, 2004 | 10:39 PM
JK996TT's Avatar
JK996TT is infamous around these parts
The install with the Targa switch is awesome and I will do it as soon as I can get the switch. Thanks very much!
Old Jun 5, 2004 | 10:49 PM
Periokid's Avatar
OK,
The problem was that the link is incorrect.
Here is the proper link...
http://www.sharkworks.net/seinfo1.asp
Old Jun 5, 2004 | 11:12 PM
Chordate's Avatar
Chordate is infamous around these parts
I want to do that mod... the only problem is that I only have two garage door opener remotes and I need both of them...
Old Jun 5, 2004 | 11:14 PM
Itzkirb's Avatar
Mehrabani
You can do two openers with one switch. I did it for Alex (Sharkster). He has a gate and a garage door. We hooked them both to one switch.
Sharkworks = 225.95
DIY = $40.00
No Brainer...
Old Jun 6, 2004 | 01:46 AM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
cool mod kirby..
too bad i wasnt able to meet you last wednesday, arling told me u were in town...
great mod, only thing im worried about is the soldering part but the mod looks great i think im gonan do it in the next couple of weeks ..
