Need DIY oil change protocol
Old Mar 9, 2004 | 01:15 PM
osu s2k's Avatar
osu s2k is infamous around these parts
I have searched the site and couldnt find a good write up on DIY oil change, any suggestions.
Old Mar 9, 2004 | 01:20 PM
Dr. T's Avatar
Dr. T is infamous around these parts
Try renntech.org, a great site for tech info. 996TT oil change
-Glen
Old Mar 9, 2004 | 02:24 PM
gregy's Avatar
gregy is infamous around these parts
Its not that hard but you need a lot of tools to get the job done. I would highly suggest buying the filter cap wrench (Porsche Part number 000 721 920 40). This thing is a ***** to remove with anything else and you will wind up scratching your filter cap with another kind of tool. There are 2 drain bolts and two turbo drain bolts (one for each turbo) for a total of 4 drains for a proper oil change. Most home mechanics do not have 27mm open wrench and a 27mm socket for the cap wrench. You need the open wrench for one of the drain bolts and the other for the cap wrench (see instructions). Also order new washers for all the drain plugs. They come in aluminum and copper, make sure you match them up with the ones you are replacing. Mobil 1 0W40 is factory fill and should be what is used. These link is for the instructions from renntech.org
http://www.renntech.org/forums/index...code=diy_oc_tt
Old Mar 9, 2004 | 04:32 PM
KPV's Avatar
KPV
Maybe this will help.........
Old Mar 10, 2004 | 10:32 AM
osu s2k's Avatar
thanks, this is exactly what i needed, a little more involved than a honda but easy enough.
Old Mar 10, 2004 | 11:02 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Keep in mind if you use jacks stands, you should use 4, so that the car is level during the drain. If the back is jacked up, some oil may remain in the front of the crank case, since the oil drain plug is in the middle of the crankcase at it's lowest point. I have not verified this fact, it's only what I have been told. It does make logical sense, imo and that is what I am going to do on my first change shortly. GT3, GT2 and TT share the same crankcase...
4ocious
Sep 1, 2015 06:44 AM
hacellular
Aug 31, 2015 08:34 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
