Demon Pulls The Trigger!!!
Old Mar 6, 2007 | 10:24 AM
  #61
MX RACER's Avatar
MX RACER is infamous around these parts
Mike, The car looks great.. I have 11.5 HRE'S on my car and they don't stick out as far as yours..
Let me know if you and Maxwell are going to meet this weekend..
George
Old Mar 6, 2007 | 10:51 AM
  #62
iLLM3's Avatar
Originally Posted by maxwell
there are a ton of threads/discussions about GT2 ride height on the TT. GT2 height is VERY low. It does look good, but it is too low IMO for daily driving. Also, if you run PSS9's (Mike, not a problem for you) you can't go as low as the GT2 anyway. There is an issue with the car riding on the bump stops, essentially taking away the effectiveness of your suspension.
Im not sure how wide my wheels are technically. I had ron (Vipertestarossa) order them for me, as he is a dealer and had the exact same wheels on his tt, so I wanted the same specs. I've never really understood the desire for a wider wheel, if the tire is the same size? 315 on a 11" wheel vs. 315 on a 12" wheel? But knowing that the GT2 runs a 12" wheel, you shouldn't have any problems, except maybe having to roll the rear fenders, as the front ones come rolled from the factory.
Yea a 12" wide wheel with GT2 offset even a bit more aggressive shouldnt be an issue, but its also stepping up to 19's which did it for me as well as my LOW drop.. BTW i was in my ex turbo driving through the city and there is no room for fingers between the well and tire, we didnt scrape anything, its all a matter of driving and we werent inching around, also how well the suspension is!
Mike you have a cream of the crop suspension buddy, you should take full advantage of it, get to GT2 spec, corner balanced and so on and you will be even more blown away, as i mentioned before Topgun Tom has JIC LOW on his car and its smooth as glass, no rebound or bump stop issues.
Here are my 12's with 315's and being at gt2 height, no rubbing what so ever, 19's will surely make it rub like you have going this low, im positive!
Old Mar 6, 2007 | 11:07 AM
  #63
Ruiner's Avatar
When I had the JICs installed, I had them corner balanced with a 1' forward rake to pre-load the front (slightly) so that there would be less transfer on hard stops/braking.
Old Mar 6, 2007 | 01:02 PM
  #64
BMWDEMON's Avatar
BMWDEMON is a jewel in the roughBMWDEMON is a jewel in the roughBMWDEMON is a jewel in the rough
MX - I'll definately let you know...I am sure we will PM back and forth especially Friday
ILL - OK...thanks for the info bro! very good stuff! I will post pics as soon as I get things set up.
amerlemans - nice wheels! Let us know when they are on and we will set that meet up!
Old Mar 6, 2007 | 01:11 PM
  #65
amerlemans's Avatar
amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !
Guys I just heard back from Dan at Vivid Racing and here is what he said:
I run it everyday (12" rears and MPS2 315/25/19 tires). You don't have to roll it at all. That is a fact.
> Obviously the coilovers have adjustable ride height. If you have the
> coilovers to low on anything, you will rub. But mine as you see lowered
has
> no rubbing and runs great! My car is set to GT2 specs with perfect camber
> for street use. The wheels do not stick out, so don't worry!
Old Mar 6, 2007 | 01:15 PM
  #66
BMWDEMON's Avatar
has
You know what...I bet you I know what I did...I had the stock wheel on the other side and just lowered it down...I am sure that is something to do with it...I will report in a few days when I get everything straight along with pics...thanks for checking into this guys! I totally appreciate it!
-oh, and I will stop worrying!
M
Old Mar 6, 2007 | 02:35 PM
  #67
iLLM3's Avatar
VERY nice, what my car is going in for right now, fully dialing my suspension corner weight/balancing and rake setup, you did it right man, Mike is lucky
Old Mar 6, 2007 | 02:51 PM
  #68
blackbenzz's Avatar
blackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of lightblackbenzz is a glorious beacon of light
As I said on the other forums, congrats Mike! Me and a few AMG guys are going to get our cars dyno'd at Funktion Auto if you want to join us. I will also be doing a track rental at MIR either the last week of March or first week of April. Let me know if you wanna go.
Oh yea, and any locals are welcome to join as well.
Maxwell- Did you get new tires from Radial yet? I should be getting my DPE's mounted and balanced there this week.
Old Mar 6, 2007 | 03:21 PM
  #69
Ruiner's Avatar
Just remember:
Dyno'ing a 996TT in AWD mode requires a Mustang Dyno (mechanically linked). I really don't trust non-linked rollers as there is a possibility that they will slow down at different speeds and possibly fry the center diff.
If you do use a DynoJet or something along those lines, you can just disco the front drive shaft and run in RWD mode only.
Old Mar 6, 2007 | 03:24 PM
  #70
blackbenzz's Avatar
Just remember:
Yea, you're right. I've seen both front half shafts of a 996TT snap on a dynojet (on decel). Funktion auto doesnt have an onsite dyno but I spoke with the owner and he will dyno our cars on a mustang dyno next door for $100. Only downside is mustang dyno's usually give lower numbers than dynojets
Old Mar 6, 2007 | 03:34 PM
  #71
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
Ahmad, is he doing it at Curry's? That's where I had mine dyno'd, and it is a Mustang Dyno.
  #72
MX RACER's Avatar
Yeah the broken axles sucks.. Be careful on the all wheel dynos..
What's up Ahmad??
George
Old Mar 6, 2007 | 03:36 PM
  #73
Ruiner's Avatar
That is correct, but perhaps you will be pleasantly surprised by the results as well. Besides, if anyone asks you the results, you can always explain that it is on a Mustang Dyno. DynoJets aren't always going to give you the best, most real world numbers that are as accurate as a Mustang Dyno. Good luck!
Old Mar 6, 2007 | 03:56 PM
  #74
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Right on. Mustang > Dynojet for real world performance. I wouldn't want to get tuned on a non-loaded dyno anyhow.
Old Mar 6, 2007 | 04:02 PM
  #75
blackbenzz's Avatar
What's up Ahmad??
George
Nothing much. How have you been? Its been a longgg time! If you wanna dyno you're more than welcome to join us (I dont know if you're still traumatized by those idiots at ProMotion Tuning) and i'll let you know about the track. I want more power but I've run out of reasonable options! Cams = 15-20hp for $5500, or nitrous 100hp for $2500. I'm working on getting a custom 80mm tb good for 25-30whp. I wanna break 11.5s and then I'll stop. The nitrous would put me in the 10's but I'm scurred of it
Maxwell- I dont know the name of the shop. He just said the shop near by has a dyno and he has access to it. You wanna hit the track? Divextreme will be coming out this time.
