I blew it UP!!!!
Old Mar 6, 2007 | 11:47 PM
  #31
TUUNER's Avatar
TUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant future
Wow, that is terrible...
Old Mar 6, 2007 | 11:58 PM
  #32
TJMONEY's Avatar
TJMONEY is infamous around these parts
Originally Posted by Kevin
At this power level, any missed shifts or high RPM runs will do the rods in a short order..
Well put!!
Old Mar 7, 2007 | 12:01 AM
  #33
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Sorry to hear about this, although it just reinforces my thoughts on building a bulletproof bottom end with my current build-up. I would rather be overbuilt than underbuilt. Unfortunately I dont think this will be the last engine to expire given the very high strung nature of many engines out there today on stock internals. Kevin
  #34
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I heard about your mishap yesterday Don. Im genuinely sorry. On the other hand, as you previously acknowledged, it was only a matter of time given the massive boost you were running on the OEM rods. I'm glad to hear that you were not injured. Now nothing is holding you back from the monster build you have been wanting to do. I see 1000 hp in your future. Good luck with your next project.
Craig
Old Mar 7, 2007 | 12:02 AM
  #35
Dr_jitsu's Avatar
True Kevin,
Actually, Sam prefers the NA GT3 for track purposes. I think he thinks I am somewhat silly when I go trolling for highway races on Sat nights. I always add a gallon of race gas when I go looking for trouble.
Of course I am 44 going on 19.
After reading this post I am a bit woried about pushing my stock bottom end.
Old Mar 7, 2007 | 12:08 AM
  #36
iLLM3's Avatar
Oh damn that's nuts, sucks to hear
Old Mar 7, 2007 | 12:15 AM
  #37
Originally Posted by Dr_jitsu
True Kevin,
You should be running more then a gallon of 100+ octane when in high boost..
ur boost at 1.4 is fine. just dont do it often on pump gas...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 7, 2007 | 12:17 AM
  #38
DMK's Avatar
DMK
DMK has a spectacular aura aboutDMK has a spectacular aura about
Umm car was making 680 to the ground trapped 138+ did a 140 in vegas Car was stock guts. 700 package tunning to the wall. Car was in pump mode with 93 in the tank wasn't killing it. Cruising in and out of boast. As for the new motor I am moving in a new direction today if it works car will TRAP 185 and Change will need wheelie bars It will have the bottom end to get that 8 sec run. We will see
I like today's motor choice
Old Mar 7, 2007 | 12:19 AM
  #39
KPG's Avatar
KPG
I have been saying this for years..
The 993 based rod doesn't have the reserve or strength, and on top of that, the interior journals get starved of oil. That is the reason why it is important to cross drill the crank.. Go talk to the road racing shops. I'd lay a 50 cent bet that it was rod # 2 that let loose.. A close 2nd bet would be #3
My prediction.. We will be seeing more of this coming to pass..
Why number 2 as opposed to any other? Kevin
Old Mar 7, 2007 | 12:38 AM
  #40
JWGT2's Avatar
JWGT2 is infamous around these partsJWGT2 is infamous around these parts
Sorry to hear...
Currently having entire bottom end built up by the guys at Sharkwerks for my GT800 package!!
Best of luck in the rebuild process...sounds like she'll be back better than ever.
Old Mar 7, 2007 | 12:48 AM
  #41
Dr_jitsu's Avatar
OK...680...that is definately too much for the stock rods. Nonetheless, I am very sorry....you have a stunning car.
Mark, I will mix 1 gallon of VP 109 w/ 2-3 gallons of 93 when I go trolling for Vettes (and I know there are several Supras and Vipers that are going to walk me when I run into them here in Houston).
For the Supra nats comming up I may go w/ a 50 50 mix.
Oh, by the way, Kevin. Sam recommended that I shift by 6500 rpms to maximize my torque band. I always shift before 6800 RPMs anyway due to my fear of blowing the motor.
Old Mar 7, 2007 | 01:35 AM
  #42
Turbo Fanatic's Avatar
That's 800+ crank HP. Well above the 700 considered "safe".
Still, this is no fun. I've blown 4 engines (all RX7 turbos) and can say from experience it totally SUCKS! Sorry to hear it.
Hopefully you can afford to buy your way out of it. I know I had a ***** of a time as a college student.
Old Mar 7, 2007 | 01:37 AM
  #43
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Sorry to hear Don. Oh well the next one will be better. What boost were you running?
Jag
Old Mar 7, 2007 | 02:17 AM
  #44
MrBlonde's Avatar
Awaiting Email Confirmation
MrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to all
If you don;t have a tune for 109 then this will hurt performance.
Old Mar 7, 2007 | 02:22 AM
  #45
he has a boost controller... its better to trade 40 HP for some blown head gaskets... just my opinion...
I would never run 1.5 bars on pump...
9.66
click to view
