changing oil
Old Mar 23, 2007 | 12:12 PM
BUFFALOTT's Avatar
BUFFALOTT is infamous around these parts
changing oil
hi everyone new to owning a porsche have had it for about a month,just finished porting and polishing stock headers and wanted to change oil and filter and wasnt quit sure on weight of oil and drain points on car. two drain plugs on crankcase and one on each turbo?, pics if aval. thanks
Old Mar 23, 2007 | 01:16 PM
kris's Avatar
kris is infamous around these parts
Old Mar 24, 2007 | 09:03 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
Yes
Crankcase,tank, 2 drips cans on turbos.
0-40 mobil one............ do not over fill!
good luck
Elliot
Old Mar 24, 2007 | 10:43 PM
PorschePhd's Avatar
Correct, 0/40 or 5/40. Drain all the plugs. The two on the turbo are the drip tanks the one on the case and the one on the oil tank. Make sure you use crush rings and the o-ring on the oil filter. When you are done fill about 8.5. You want it just shy of the full mark. It will smoke less on start up and if tracked will not push up into the MAF.
Old Mar 25, 2007 | 05:54 AM
Ruf 550's Avatar
Ruf 550 is infamous around these parts
I use Castrol TWS Motorsport 10W-60, same as M3 CSL. Very good but expensive.
Ruf 550
Old Oct 1, 2009 | 05:56 AM
XLR82XS's Avatar
Anyone have any feedback/info on the TWS? I hear its "the bomb" and makes all other oils look like crap.
Old Oct 1, 2009 | 09:18 AM
landjet's Avatar
That weight oil is not on the Porsche approved list. There are no 10W or 60 weight oils in that list. 5W50 is the highest.
Old Oct 1, 2009 | 09:44 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
i talked to a p dealer mech and he said 50 was fine, especially if ambient temps are hot and the car is driven hard. i use 15w 50. My tuner recommended 60 even. But you'll find there's lots of opinions regarding engine oil.
dont forget to suck out residual oil from filter location and not to over tighten oil filter cap
SharkyShark20
Sep 19, 2015 09:54 PM
away
Sep 4, 2015 12:30 PM
Sales@RSW
Sep 3, 2015 09:34 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
00aston
Aug 27, 2015 12:01 AM
