will a 275/40/18 fit on the turbo????
I am going to get some Nitto NT-01's but the only options I have is 315/30 and 275/40 in 18 for the stock turbo twists. I dont want more sidewall for sure because this os for track and the more sidewall, the less rigidity. Has anyone put 275's on their turbo wheels????
Dez,
I believe that Nitto also makes a 275/35ZR18. Diameter is 25.55 as opposed to the tire you mentioned which is 26.55. Don't know if that would create problems with your AWD, but it could. Nitto also has a 245/40ZR18 which is 25.55 and would be a good match for the 315's you plan for the rear at 25.35. I went with the 235/40ZR18 with diameter of 25.39. I chose this over the 245's for not knowing if they would give any fender well problems. If you get the 245's then I will have a better idea as to fitment assuming our ride height and camber is similar. The 275's are going to want a wider wheel with the ideal being 9.5"
Woodster and I both assumed you were talking about the front tires and not the rear.
If you are going for the 275's on the rear, then it seems that the 275/35 would be a better choice than the 275/40.
When you chase after some more horsepower, you may wish you had chosen the 315's
The NT-01 seem to be available in a bunch of close sizes now:
225/40R18
235/40R18
245/40R18
http://www.nittotire.com/#index%2Etire%2Ent01%2Esizes
225/40R18
235/40R18
245/40R18
oddjob142
Aug 19, 2015 12:27 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Turbo Vendor Classifieds
Aug 18, 2015 03:55 PM
