Diverter valves: Maintenance or Performance ??
Old Feb 27, 2007 | 01:47 AM
ramone's Avatar
ramone is infamous around these parts
Diverter Valves are sold as Part of Evoms's Stage 1 +
On their website it states: "Our valves will restore lost power and will hold more boost pressure than the stock units for added performance. In addition, they recover quicker than the OEM valves which allows better spool up after shifts."
Link
and: "The stock valves are only able to hold up to the stock .7 BAR of boost. Once the boost is increased to 1.0 BAR, it is a necessity to change the stock valves to achieve the stated power gains."
Link
Is this all accurate ?
Old Feb 27, 2007 | 08:47 AM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
The stock valves contain a rubber diaphragm that tends to rip. The result is you lose significant boost due to the leak. Porsche, VW, and audi has used this technology since the early 80's and for some reason are still using it (though an updated valve that fails the same way). Typically by 30k miles on turbo applications from the aformentioned manufactures, we see the valves have failed. Also when you run higher boost, it puts more strain on the valve and it will fail.
The billet valves on the other hand do not fail because they have an aluminum plunger/diaphragm that will not rip or tear like the stock units.
They can take much higher boost. Replace the valves with billet units, and don't worry about it anymore
Old Feb 27, 2007 | 09:05 AM
wross996TT's Avatar
As the Doc says...they are for PM.
Old Feb 27, 2007 | 11:18 PM
ramone's Avatar
Wow. Thanks
Old Feb 28, 2007 | 08:26 AM
Here is a picture of the billet valve. You can see the aluminum plunger/diaphragm. It is a very well made piece.
And here is a picture of the stock valves. I cut the top off to show the innerds. The red arrow points to the rubber diaphragm that will split and fail, therefore the pressure can not push the plunger up against the pressure of the spring, resulting in lost function. Along with the rubber diaphragm, you can notice the plastic plunger that rides on it.
Old Feb 28, 2007 | 01:23 PM
buddyg's Avatar
A picture is worth a thousand words thanks Doc!
Old Mar 24, 2007 | 02:52 AM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
where can the billet valves be purchased?
Old Mar 24, 2007 | 03:26 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
Is there any easy way to tell if the valve has failed?
Old Mar 24, 2007 | 03:34 PM
wross996TT's Avatar
Old Mar 24, 2007 | 04:33 PM
heavychevy's Avatar
+1...........
Old Mar 24, 2007 | 08:04 PM
996TTDave's Avatar
Thanks and which would you recommend?
Dave
Old Mar 24, 2007 | 08:43 PM
vrusso's Avatar
vrusso is infamous around these parts
what is the approximate overall cost for billet dv's with installation?
Old Mar 25, 2007 | 05:27 AM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
Dave
almost everybody on the site is running the EVOMS ones. My friend has them on his 996TT and hasn't had a single problem with them.
Old Mar 25, 2007 | 11:15 AM
wross996TT's Avatar
The Forge is the one I and some tuners would recommend!
Old Mar 25, 2007 | 08:32 PM
cohare's Avatar
One more time, is there an easy way to tell if these have failed? I have 27K on mine I hear 30k is around where they fail...
I would think it would hold less boost, so maybe it wouldnt go to .7 bar?
Also, will the aftermarket ones void a warranty?
