pic request for those using pss9s
Old Apr 4, 2007 | 07:52 PM
kayman's Avatar
kayman is infamous around these parts
can someone with a pss9 setup post a side pic of their car on the lowest recommended setting? I'm thinking of installing these and would like to get an idea of how low they can go. Thanks!
Old Apr 4, 2007 | 07:55 PM
Zookie's Avatar
https://www.6speedonline.com/forums/...ad.php?t=76322
This is the lowest Recomended Setting by a local Porsche Performance Shop "Autowerks"... After begging them to SLAM (SLAMATION NATION WESA!!) my car, they said this is the lowest I should go without Rubbing and damaging something overtime, starting with the "Drive Shafts"
If you want Slamation Nation, go with H&R Coilovers, they go much lower...
Old Apr 4, 2007 | 07:56 PM
MiniDHinkle's Avatar
My brothers 996 with pss9's.
Old Apr 4, 2007 | 07:57 PM
kayman's Avatar
thanks guys. this helps alot
Old Apr 4, 2007 | 08:00 PM
Zookie's Avatar
Go with H&R for Slamation Nation, you will be a Happy Camper... If you want Comfort then PSS9's
Old Apr 4, 2007 | 08:02 PM
kayman's Avatar
im not really looking to slam the car. just want something that has the best combination of price, comfort, height and handling. Wont be tracking the car either, so I thought pss9s would be best. but ill also look into the h&r setup. thanks.
Old Apr 4, 2007 | 09:29 PM
kayman's Avatar
can pss9's bring a 996tt down to gt2 height?
Old Apr 4, 2007 | 10:51 PM
wross996TT's Avatar
No, this is not recommended...you will be riding on the bump stops.
Old Apr 4, 2007 | 11:09 PM
Zookie's Avatar
GT2/GT3 uses H&R Coilover that was re-done by Porsche or TecArt
Old Apr 4, 2007 | 11:58 PM
kayman's Avatar
in that case, i think ill be happy with the pss9's limit
Old Apr 5, 2007 | 12:44 AM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Not the lowest setting but getting close.
Old Apr 5, 2007 | 12:48 AM
sharkster's Avatar
on a 996tt don't go more than 1.25 inches in the front. That kit isn't designed to be slammed and if you go much lower you'll ride on the bump stops. Not a good situation.
Old Apr 5, 2007 | 01:21 AM
kayman's Avatar
carnerd: have you had any problems with hitting the bump stops or bottoming out with your current setting? Hows the handling & ride compared to stock?
Old Apr 5, 2007 | 01:56 AM
kayman's Avatar
also wondering what is everyones opinon of the system? is it an improvement over stock?
Old Apr 5, 2007 | 02:32 AM
Turbo Fanatic's Avatar
Anything lower than this was bottoming out and affecting handling IMO. The rear is a little raised for rake (looks). I started low and gradually raised until it felt good.
The ride is super supple, much smoother than stock, and tightens when you push it. It truely is a dual mode system.
