Flat Tire Repair on Michelin PS
Old Apr 6, 2007 | 11:56 AM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Got a small nail in my 315 MPS that I bot at Tire Rack. I took it to a shop that had a "no touch machine" so I could be sure they wouldn't scratch up my factory GT2 wheel. Afterward, I wondered if I should have just replaced the tire, since I get into the triple digits often. I didn't even think about at the time. Should I replace it? Does the repair weaken the tire significantly?
Old Apr 6, 2007 | 01:26 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
David,
I had a nail puncture in one of my 315's last year. The authorized Michelin dealer said that the only way to properly repair the flat was to dismount the tire, grind the inside area quite a bit around the hole and use a proper patch. I watched him do it...plugs are not acceptable.
He also said Michelin says you can only have one puncture repair on a high performanace tire for safety reasons...sounds like a smart idea but just means more $$$ for the dealer/Michelin...dunno how true that last statement is though..common sense I guess.
Ben
Old Apr 6, 2007 | 01:38 PM
Eric523's Avatar
Eric523 is infamous around these parts
I would recommend replacing the tire if you plan on driving at three digit speeds. I definately would on my own car, mostly likely both rears at the same time. It is a lot easier to recommend it than go write a check for it though, so it's really what you feel confortable with. The last thing I want in the back of my mind while cruising over 100 is fear of a blowout.
Old Apr 6, 2007 | 02:00 PM
dtmarsh's Avatar
Thanks, guys.
Ben, That's a good point about a plug repair. There's no way I would allow that. they did a "proper" patch on the inside of the tire. On another note, what did you ever do w/ that OME flywheel?
Old Apr 6, 2007 | 10:53 PM
BigBadBen's Avatar
Hey David,
It is in the car right now, I dropped the motor two weeks ago and replaced my Tilton triple disc for the dual mass you sold me and a single disc Sach's setup. It's so nice to have the dual mass back in. Changed a leaky injector 3 and plugs at the same time. She is running very strong now as I have the new EVOMS Hitachi MAF and new program.
Ben
Old Apr 6, 2007 | 11:58 PM
20C4S's Avatar
we use the patch with plug. 2 in 1. if u need it i'll send u one. let me know.
Old Apr 7, 2007 | 12:16 AM
dice996c4's Avatar
dice996c4 is infamous around these parts
Have you guys tried using a tire liquid sealant ? Does that thing work ?
Old Apr 7, 2007 | 12:21 AM
20C4S's Avatar
it's like having sex. u don't want to take chances.
Old Apr 7, 2007 | 12:41 AM
dice996c4's Avatar
PAULUNM
14
May 27, 2016 06:54 AM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
immaculate
Aug 31, 2015 05:32 PM
L.A.P.
Aug 23, 2015 11:48 PM
