What setting do you have your JICS on?
Old Apr 11, 2007 | 08:49 PM
cpu77's Avatar
cpu77 is infamous around these parts
What setting do you have your JIC Coilovers on?
Well Got my car all done. I have them on the lowest Soft setiing right now. Car bounces all over the place! What settings do you guys have yours on? Please say 4 cliks from hardest or 5clicks from softest.
Ralph
Old Apr 11, 2007 | 10:31 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
two in front, 4 in rear but thats for 8/10 set up is what I run. No bounce
Suman
I also have sway bar set front and rear set in the middle.
Old Apr 11, 2007 | 10:32 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Speakings of JIC's. Anyone know how they compare to the PSS9's? I'm thinking of switching. Thanks!
Old Apr 11, 2007 | 10:35 PM
cpu77's Avatar
Which color springs you have? Mine are puple.
You mean 2 clicks from the firmest setting?
Old Apr 11, 2007 | 10:56 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
He means 2 from softest and 4 from softest.
I run mine 5 front 8 rear from softest on a 965 . w/10 & 14 KG program..
.I did find when you run too soft it does not work well you fell the springs only little damping.
Old Apr 11, 2007 | 11:36 PM
dice996c4's Avatar
dice996c4 is infamous around these parts
4 in the front and 7 at the back (from the softest)....
Old Apr 11, 2007 | 11:44 PM
Highhats's Avatar
mine from the softest and I have purple springs thanks
Old Apr 11, 2007 | 11:56 PM
cpu77's Avatar
I was using the softest setting and the cars steering was very twitchy.
Old Apr 12, 2007 | 09:17 AM
kris's Avatar
kris is infamous around these parts
I have this problem too, how do you dial out the twitchy feeling in the steering?
Old Apr 12, 2007 | 09:23 AM
Divexxtreme's Avatar
Which JIC setup did you get? They make 7/10 KG, 8/12 KG, and 10/14 KG. I have the 7/10 KG setup and it rides better than stock.
Old Apr 12, 2007 | 09:26 AM
kris's Avatar
I have 7/10, it must be a matter of setup, but I have the twitchy steering that CPU mentions.
Old Apr 13, 2007 | 08:35 PM
Bill in Atlanta's Avatar
Bill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud of
Get your car aligned, correctly, NOW !
Trust me, that is the issue.
It will be perfect when done
Bill
Old Apr 13, 2007 | 09:47 PM
Highhats's Avatar
I agree with Bill. Alignent is whats wrong. My car is not twichy at all after the alignment.
Suman
Old Apr 13, 2007 | 10:55 PM
WOODTSTER's Avatar
I have 8/12 and mine is stiff!
I will try softer settings. I have set right in middle between soft and
hard. Mine is not twitchy at all, steer in and driving on freeway is all good.
Marty K.
Old Apr 14, 2007 | 06:07 PM
Highhats's Avatar
Guys also I use 36/40 cold PSi for my tire pressure for the JIC's. this helps rear bump skip which I used to have at 44 lbs. so again 36/40 and 2 clicks from soft front and 4 clicks from rear. I have the 8kg fronts and the 10kg rears so MArty unlike you my rear is softer. I would try 2 clicks form soft all the way around and 40 in the rear tire cold. Let me know if that helps your set up at all. Mines a dream!
Suman
