anyone do Guard taller gears 1st-6th on the 996tt?
I want to get out of first past 60mph and 4th past 145mph. Im assuming I will need to revise every gear. has this been done. I recall bigbadben did gear revision but I could not find the specifics on it. Any help is greatly appreciated. thanks
Suman
Suman
Suman,
if u had higher rpm range u would do 145 in forth no problem....
2001 996TT 3.6L and stock ECU
I have a 64mph 1st gear on my sequential gearbox and it is quite difficult to drive on the street. For a track that has 30-50mph exit speed corners it is great but if the objective is to achieve fast 0-60mph it will not work. You will be off boost for too long, unless you have a stock turbo.
Don't waste your time re. the first gear. A taller ratio gearbox will make you go faster except off the line. As Markski said, best option is to raise your rev limiter if the engine is built accordingly.
I think you guys can run 7500 rpms without a problem....
markski
markski
i would argue w/ some of the above - on a gt750, a taller first gear *would* absolutely help acceleration. 1st gear goes by way too quickly in my gt700.
from bigben's past posts, it seems like a revised 1-4 would result in blazing acceleration on a gt700+ set-up... it sounded like 5th & 6th would be best left stock (or near it.)
(edit: i would love to up the redline of the gt700's 7k or so... 7500 would be *nice*. w/ built internals, i don't see why it couldn't be done.)
- chuck
- chuck
As Chuck said we cannot do 7500 RPM with stock internals on a GT700 etc, I spoke to Todd about this. The internals would have to be done first which is a same but be don't want to blow things up do we!
I think what I have done with 1st etc makes a lot of sense and works really well...agreed 5th and 6th could have stayed as is but I am happy with it to be honest as my new programing gets me higher speeds now when compared to the Boxster MAF I was running.
BBB,
We still would love to see your accerlation #'s from 60-130 mph !!!
I thought you had a drift box for awhile?? I looked into taller first few gears
and as BBB can tell you, you are quickly over $10-12,000 for the transmission work only. I am rebuilding mine with new (stock ratio) gears and then adding some steel synchros (to replace the mushy brass ones)
Marty K.
MK
Marty K.
MK
I would love for the program to go to 7500rpm. I have pushed the envelope on this stock motor I think its still in her.
