Help installing B&M ssk
Old Mar 22, 2004 | 11:44 PM
jpatrick's Avatar
jpatrick is infamous around these parts
Man I must be an idiot LOL. Everywhere and everyone says you can install this thing in about an hour, but I'm not off to a good start. I'm just working off the instructions that came with it and I'm already stuck on step 3 - removing the shifter ****. This is in an 03. It says to use a 5mm hex key or some ***** use a set screw blah blah blah. Well I've lifted up the leather shifter boot and I can't find *anything* that secures the **** on there. And it doesn't seem like it twists off. Am I just a retard? And then looking ahead to step 4 - "unsnap side covers from center console". Could the instructions be any more vague? Which direction do you pull from? I don't want to go breaking off the tabs on every piece I have to remove and have to replace them all. I've installed a B&M in my past 3 cars and never had this kind of problem. Am I a retard? Am I just too scared to mess up my brand new car? Anyway, does anyone know of a more detailed instruction manual for install the B&M and/or removing the rear center console etc that might help me out? Search is down and I need some help here.
Old Mar 23, 2004 | 12:16 AM
msindi's Avatar
What shifter do you have? I think the set screw to be removed with hex only comes in the optional shifters like carbon, wood and aluminium
Old Mar 23, 2004 | 12:27 AM
jpatrick's Avatar
I just have a regular old "normal" shifter. So do I just pull it off? I'm tugging on the damn thing and it won't budge.
Old Mar 23, 2004 | 12:50 AM
msindi's Avatar
did you check www.renntech.org/forums? pretty sure it just snaps off like everything else in the car...
To unsnap side covers on center console (where cd holder, etc. is) I found that the best way is to grab the pieces from behind (i.e. all the way in the fornt of the car) and then push towards the back of the car and pull sideways nad outwards...real easy and they're sort os sturdy so dont worry...
DO NOT FORGET TO MARK THE CABLES BEFORE REMOVING STOCK SHIFTER!!!
Old Mar 23, 2004 | 01:33 AM
jpatrick's Avatar
Too late ... I already removed the stock shifter. Finally just yanked on the damn **** as hard as I could and it finally came off. Instructions didn't say anything about marking the cables. We shall see ...
Edit ...
OK that wasn't that bad after all. I could probably do it in an hour the 2nd time LOL. I didn't go for a drive yet but everything is back together and all gears seem to engage fine. I wonder why the instructions that come with the SSK don't mention anything about marking the cables? It didn't seem to be necessary in my case, because they didn't really move between the time I unhooked them and hooked them back up. The driver's side cable I just hooked right back up, and on the right side I installed the Evo billet shift linkage piece so I had to mess with that a little, but it was no big thing.
It seems a little notchy but I'd rather have it this way than stock. Does the "notchyness" go away at least a little once you shift a few hundred times and it loosens up a little, or does it pretty much retain the same feel as when its first installed?
Old Mar 23, 2004 | 04:14 AM
maxjamie's Avatar
Porsche Rocks
maxjamie is infamous around these parts
the notchy shift does appear to loosen up slightly. I have had my B&K for about 8 months now. I still love the difference from the stock shift.
Old Mar 23, 2004 | 07:08 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
I did the same install you did with the B&M and Evo shiftlink. It starts off way notchy but it will improve quite a bit with use.
MadWhip
Sep 3, 2015 02:04 PM
takenotes996tt
New Member Introductions
Sep 3, 2015 10:12 AM
orbelo
Aug 30, 2015 12:26 PM
