Gt2 front vent
Old Apr 27, 2007 | 10:13 AM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Gt2 front vent
What do you have to do to remove that vent? I am going to replace it with one made of carbon fiber.
Old Apr 27, 2007 | 10:21 AM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
The correct way is to remove the bumper to get at all the screws...
If you want to cheat cut the OEM plastic piece out with a side cutter and then install the carbon piece, either way it's kind of a PITA
I will attach a pic of my GT2 with the carbon installed tonight
Old Apr 27, 2007 | 11:00 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
It is best to remove the bumper skin to do it properly. I installed my Techart bumper...not too bad if you have a lift to use.
https://www.6speedonline.com/forums/...ad.php?t=44095
Old Apr 27, 2007 | 11:09 AM
9Eleven's Avatar
Will jack stands do the job if you don't have a lift?
Old Apr 27, 2007 | 11:13 AM
If you are not removing the bumper you will not need a lift...everything is done from the top
Old Apr 27, 2007 | 11:16 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
You don't need a lift to remove the bumper. I did mine on my garage floor. 20min job.
Old Apr 27, 2007 | 11:20 AM
M3CAB's Avatar
Actually, you guys are right about not needing a lift. When I did my install, I had to remove the fender linings and underbody plastic cover. Since you are only removing the front skin, it should be a lot easier.
Old Apr 27, 2007 | 08:07 PM
Cerberus's Avatar
Cerberus is infamous around these parts
Could you please shed some light into how you can swap the front diffuser vent on the GT2 in such a short time. Inquiring minds want to know.
Enemy
Nov 10, 2015 08:01 AM
tkebp1275
Aug 31, 2015 06:35 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
TrackOne
Aug 20, 2015 12:56 PM
m_motorsport
Aug 19, 2015 03:34 AM
