headlights flicker
Old May 4, 2007 | 08:43 PM
kayman's Avatar
kayman is infamous around these parts
headlights flicker
is it normal for the xenons to flicker when driving over bumps? I just noticed this today. It happens only on the really rough bumps.
Old May 4, 2007 | 08:49 PM
porschenut911's Avatar
porschenut911 is infamous around these parts
I don't think they flicker, I think they try to adjust which looks like a flicker unless you have something loose.
Old May 4, 2007 | 09:42 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
I second the looseness get a 5mm socket and take the mushroom off the side panel where the headlight is. make sure the light is completely locked in. Unlock it with one click counter clockwise. pull it out... put it back in and turn the **** one noisey click clockwise Youll know when its lock in place. Happened to me also. GL
Suman
Old May 4, 2007 | 10:07 PM
tsky's Avatar
tsky is infamous around these parts
I had the same symptoms: both lights would flicker if I hit a good bump. It was noticeable enough that I was afraid they were going to flicker out and not come back on. I took it in under warranty so I don't know exactly how they fixed it but I believe there was an electrical connector that came loose. I seem to recall the connector was not in the headlight assemblies but somewhere else. I'll try to find the invoice for that one.
Old May 4, 2007 | 10:45 PM
kayman's Avatar
thank you for the suggestions. The lights also flicker if I slam on the brakes.. so it definitely seems like something is loose. I'm going to check the bulbs tomorrow.
tsky: if you can find that invoice.. thatd be really helpful.. itll save me a trip to the dealer if it turns out the bulbs are not the problem.
DYL 911
Oct 20, 2025 05:08 PM
adnanm3
Oct 25, 2016 08:38 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
DYL 911
Oct 1, 2015 02:47 PM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
