2002 TT Xenon Headlights Don't Work
Old May 11, 2007 | 01:10 PM
911mike's Avatar
911mike is infamous around these parts
My xenon headlights just won't come on at all. I am running the regular headlights but I was spoiled with the xenon. Any tips to fix at home?
Old May 11, 2007 | 04:49 PM
KJM3's Avatar
KJM3 is infamous around these parts
If both Xenon's failed at the same time, it might just be something simple like the headlight fuse!
- KJ
Old May 11, 2007 | 08:04 PM
phaphaphooey's Avatar
phaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond repute
- KJ
qft. hids are supposed to last the life of the car with a name brand bulb/ballast system (certainly including oem), for both to go out at once is unheard of.
Old May 12, 2007 | 07:53 AM
911mike's Avatar
Unhappy Xenon Headlights
Is there a separate fuse for the xenon headlights only? All of the other lights in the assembly function fine.
Old May 12, 2007 | 08:25 AM
andyk79's Avatar
andyk79 is infamous around these parts
Probably one of two things. You have bad bulbs, or the unit that feeds power to the xenon bulbs are faulty.
Old May 12, 2007 | 08:29 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I would say a fuse since it seems like they both cut off at the same time.
Old May 12, 2007 | 09:13 AM
911mike's Avatar
Thumbs up Xenon Headlights
Is there a separate fuse? I'll look again when I get home....thanks.
Old May 18, 2007 | 07:44 AM
911mike's Avatar
Wierd thing, last night driving home I flicked on my high beams and all of a sudden the xenon's came on. Any ideas where to check? Switch? Looking for a DIY fix.
Old May 18, 2007 | 10:12 AM
exoticalex's Avatar
exoticalex has a spectacular aura aboutexoticalex has a spectacular aura about
Did the xenons stay on after you flicked the high beams? Maybe you have a faulty light switch....?
Old May 18, 2007 | 09:50 PM
TurboLove's Avatar
TurboLove is infamous around these parts
my .02, post your issue on renntech.org; that site is all about car issues, etc. great resource!
good luck!!
Old May 18, 2007 | 10:43 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I had a similar issue -- intermittant inoperative headlights, which got progressively worse. It turned about to be a faulty swicth which, according to Speed Gallery, is not an unusal occurrance. Its a simple and relatively inexpensive fix.
Craig
Old May 19, 2007 | 05:26 AM
esemes's Avatar
esemes is infamous around these parts
Craig
craig--
my switch sometimes doesnt light my xenon's either..
(intermittent, too; getting worse it seems)
how do i pull the switch assembly out to replace it??
-ese
Old May 19, 2007 | 02:09 PM
Craig's Avatar
Originally Posted by esemes
craig--
-ese
Call Speed Gallery -- they are familiar with the issue. SG is a board sponsor -- click on their link and ask for Dan or Sam -------->
Old May 19, 2007 | 04:38 PM
justdumb's Avatar
justdumb is infamous around these parts
A faulty ignition switch can also cause this problem.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
MDYUKI1016
Aug 24, 2015 04:40 PM
metzkaro
Aug 24, 2015 02:59 PM
PelicanParts.com
Audi Vendor Classifieds
Aug 21, 2015 01:28 PM
