Blew my MAF today
Old May 17, 2007 | 07:01 PM
kris's Avatar
kris is infamous around these parts
Angry Blew my MAF today
What a pisser...stood on the car in third gear and lights, bells, whistles, into limp mode with PSM/ABS lights. My car has <10K miles, has aftermarket exhaust, ECU, Forge DV's, silicone hoses and a properly maintained K&N drop in. The replacement up here in Canada was $600!!!
My mechanic told me it had nothing to do with the car setup, it's just that the Porsche MAF's are lousy. Any advice here - is there a better MAF that is simply a direct replacment? Or do I need to stock up on MAF's? I'm planning on going stage 2 UMW..will this be more of an issue with those additional mods?
Old May 17, 2007 | 07:22 PM
andyk79's Avatar
andyk79 is infamous around these parts
If you are planning on going with UMW Stage IIs, I believe Kevin provides you with another maf that he has custom fabricated that works with his setup. You should give Kevin at UMW a call.
Old May 17, 2007 | 07:24 PM
wross996TT's Avatar
Wow..that is arip off...can't you buy them cheaper?...About $250 at:
MAF
Kevin will take care of you...I have had no problems since removal of the V-flow...
Old May 17, 2007 | 07:42 PM
kris's Avatar
MAF
You're right I got hosed on the price. Thanks for the info.
Old May 17, 2007 | 07:46 PM
what ECU are you running....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 17, 2007 | 08:20 PM
kris's Avatar
Gembella ECU
Old May 17, 2007 | 08:37 PM
did the temps change today by a big margin?
9.66
click to view
Old May 17, 2007 | 08:40 PM
kris's Avatar
YES they did??? - what are you getting at, Jeddi master
Old May 17, 2007 | 08:50 PM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Even though you say your K & N is properly maintained, the oil type filters are known to damage the MAFs. I would lose the K&N and get something "dry".
Old May 17, 2007 | 09:11 PM
wross996TT's Avatar
Really don't want to start another argument, but anyone that says they know what causes this definatively is OTL. There is not one thing that has been "proven" to cause MAF failures. It is likely an interaction of several causal factors...but to say it is due to oil on the filter...not known (everything I've seen is correlation at best). In fact, there was a study with data posted by K&N about effects of oil on MAFs..which was notta (I suppose this also could be biased). My point is nothing is a known. FWIW.
Old May 17, 2007 | 09:24 PM
I happen to know a little more about this then post... thank God my tuner has it figured out.
How long On the chipped ECU?
9.66
click to view
Old May 17, 2007 | 09:52 PM
kris's Avatar
I bought the car 2 months ago with the Gembella ECU. I've swapped it a few times since then with the stock ECU, but it's been in for the last 6 weeks. Don't know how long that PO had it in the car.
Old May 17, 2007 | 09:56 PM
So you have two ECU's???
did it get colder today or did it get hotter?
Its probably the ECU coding...
9.66
click to view
Old May 17, 2007 | 10:03 PM
kris's Avatar
Yep I have 2 ECU's, factory and the Gembella. Factory is only used for emissions testing
It dropped from 80 degrees to 50 degrees today
Old May 17, 2007 | 10:14 PM
ard's Avatar
ard
Oil will not typically cause catastrophic MAF failure- oil will foul the mafs, leading to distorted AFRs and then a CEL eventually. The sudden death of a maf is over-ranging or perhaps spiking due to wacky flow. Two distinctive failure modes. A
