Dyno results?
Old Apr 1, 2004 | 02:36 PM
EL750's Avatar
EL750 is infamous around these parts
Dyno results?
After a couple of days on the dyno we managed to start correcting the ECU. Problem was that we were experiencing violent wheelspin the first day so they had to lift the suspension (for some reason) and plant the car down. Even then, there was violent wheelspin above 5k and 6.7k rpm turbo's themperature reached 400F and airintake 175F while on the Dyno. On the street .285F and 100-120 respectively. Max boost on Dyno 1.3 bar .....on the street it pulled steady 1.4bar. above 5Krpm EXT temp full thottle reached 1700F With some timing advancement this should be reduced.
I have not seen the dyno graph yet but due to wheelspin don't think it would do much good . I will take it to another dyno with some shaved slicks on my part. The are also getting a new engine Dyno next month so I may try that as well.
Max power appox 480KW@7200rpm (approx.650rwhp-745crank)
This is the weird part now . Max torque is 630ft @ 6000rpm. This has me confused. It may be because of the large Turbos and restriction of Boost in the low-mid range. It just doesn't make sense to me.
The car is progressive and solid up to 4K from 5K to 7k it pulls like 'hell'. (That was TTP's quote.)
Next Dyno Run should be end of next week. Hope it's a better one.
Old Apr 1, 2004 | 02:41 PM
msindi's Avatar
WOW!!!
Old Apr 1, 2004 | 02:56 PM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
Question
Maybe I missed the info. on previous posts but what mods were done to the car to achieve these numbers?
Old Apr 1, 2004 | 03:08 PM
EL750's Avatar
It was a full engine job. New titanium rods liners pistons,ported heads with larger valves, high lift custom cams, custom intake, larger throttle body, K-26 with k27 internals 8mm shaft Turbos large injectors secondary fuel pump raised fuel pressure. Two stage oil pump. Reinforced block, lightmass flywheel gt-2 middle housing gearbox gt-3r internals ss syncro's. The rest is the same as in a bolt on mod.
www.hobbystage.net/porsche/elliot
Old Apr 1, 2004 | 05:28 PM
Bruce's Avatar
Member
Thumbs up
I agree, WOW
Old Apr 1, 2004 | 05:59 PM
cjv's Avatar
cjv
Moderator
Elliot,
Very impressive. Your motor sounds just a bit better than my first motor. At 1.2 bar I believe I was at 636 rwhp and 609 rwt. Congraduation Elliot. I don't believe the maximum numbers are telling the whole story. With those titanium steel rods you are accelerating way faster than those heavy stock rods.
Old Apr 1, 2004 | 08:12 PM
KPV's Avatar
KPV
Elliot,
You mention "reinforced block" in your list. Can you expound on this? What was reinforced and how was it achieved?
Old Apr 1, 2004 | 08:33 PM
gt3Steve's Avatar
gt3Steve is infamous around these parts
KPV: I believe the reinforcing referred to was shuffle pinning the case (pictures were posted in another thread). Porsche has also changed to a "Made in Spain" engine case which is unique to the water cooled motors and looks to have some additional reinforcement not present on the 964 part numbered case.
Old Apr 1, 2004 | 08:36 PM
KPV's Avatar
KPV
I am a little confused....
1. Shuffle Pinning?? Please elaborate.
2. "Made in Spain" cases. I thought Elliot started with a standard water cooled 996 turbo case?
Old Apr 1, 2004 | 08:49 PM
cjv's Avatar
cjv
Moderator
KPV,
Pins that are drilled into the main webs, closer to the crank. It helps to keep the crank from moving, especially at high rpm's and torque levels.
The newer cases were introduced in the 2004
http://hobbystage.net/porsche/elliot/
Pic T1103 is what shuffle pinning looks like.
Old Apr 1, 2004 | 11:28 PM
EL750's Avatar
Thanks Chad. Can't wait to get it back. There are some traction problems that you had mentioned. Have to get Michelin cup tires on 18's. He has to set up the suspension now. Also we haven't added the intercooler spray yet. This is a must. I will add this later.
The light flywheel with titanium rods have improved throttle response and accelaration dramaticaly. Thank you for helping out in this matter.
Old Apr 2, 2004 | 03:38 AM
MrBlonde's Avatar
Awaiting Email Confirmation
MrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to all
That is a bucketload of work. Well done!
Old Apr 2, 2004 | 04:47 AM
EL750's Avatar
We still have room to advance timing by about 3 degrees. This and Intrcooler fluid injection system will be done in June on the new dyno .
Old Apr 2, 2004 | 05:38 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Man does this sound like fun work! Please keep us informed.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
TitanMotorsport
Nissan GTR
Sep 23, 2015 03:25 PM
webcarconnection
Sep 21, 2015 10:54 AM
