Dyno'd my Proto 650 today, results inside....
Old Jun 23, 2007 | 09:24 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Nice... Congrats! I'm hoping to have mine dyno'ed soon on a Mustang...
Old Jun 23, 2007 | 09:30 AM
sharkster's Avatar
congrats and once you get the AFRs dialed in you'll have a fun set up Careful of AWD dynos. Take it from someone that had his differential blow out on a non-mechanically linked dyno (4 years ago now?).....
Old Jun 23, 2007 | 09:34 AM
PorschePhd's Avatar
Not the first time you have puked all over the place
Old Jun 23, 2007 | 10:22 AM
sharkster's Avatar
hey.... what happens in vegas stays in vegas- including any "chunky bits".
Old Jun 23, 2007 | 11:00 AM
heavychevy's Avatar
That's some great info to know, gotta commit that one to memory. NO AWD DYNO JETS!!!!! NO AWD DYNOJETS!!!!!
Old Jun 23, 2007 | 11:05 AM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
If you do then just disconnect the shaft.
Old Jun 23, 2007 | 11:29 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Thanks for the replies guys. Now the question is, how do I check my diff for any possible damage? The car seems to drive fine with no stange noises. I was told that Auto cars are a lot more susceptible to damage.
I talked to Todd about the #s and he told me the #s were very good for AWD. He also thought my car is running out of injector thus the lean conditions up top.
Old Jun 23, 2007 | 11:33 AM
sharkster's Avatar
Don, mine was a tip as well. Start looking for sweet smelling drops of fluid. Check under the belly pan in the front etc.... If you have a leak of any kind like that you're in trouble
Old Jun 23, 2007 | 09:32 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Congrats on the numbers, I wouldnt worry too much about the front diff since 14.0 AFR's at WOT will burn a piston first. Those AFR's are WAY too high and no motor is going to last very long with those AFR numbers. I would turn down the boost or upgrade the fuel system/injectors.....
Old Jun 25, 2007 | 05:11 AM
wirx's Avatar
wirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud of
I tried some days 4wd dyno...but front wheels spin only slowly, so I get no number...
How this look like Custom Aluminum Intake Plenum (FVD Style) I plan to change my plenum soon...
Old Jun 25, 2007 | 07:55 AM
taizen's Avatar
taizen is infamous around these parts
The Porsche dealer (Porsche Exchange) with an AWD Dyno Jet also disconnects the front drive shaft when they dyno a TT.
Old Jun 25, 2007 | 10:15 AM
dr_sharp's Avatar
dr_sharp is infamous around these parts
Wow, how can the DynoJet then be considered an AWD dyno if it only damages AWD cars? Is there a different type of diff on most cars that allow for different wheel speeds without damage? Thanks for the info.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
