Europipe install charge
Old Jul 12, 2007 | 06:03 PM
NSD991's Avatar
NSD991 is just really niceNSD991 is just really niceNSD991 is just really niceNSD991 is just really nice
How many hours should it take to install the europipe exhaust on the 996tt and what is a fair price? Thanks.
Old Jul 12, 2007 | 06:52 PM
Mikelly's Avatar
Hmmm...
I installed, and then swapped, and then reswapped exhaust a couple of times with jackstands and I can tell you that there are 10 bolts (8 for the turbo flange studs and two for heat shealds) and the rear mounts (2) and disconnected the four (4) 02 sensor connectors and fed them down (and then back up) for clearance/connection... I'm pretty sure I had an hour total each time I did this...
What kills me is I had a buddy pay $500 to have pads swapped and brakes bled. This is like, an HOUR at best??? There are a lot of guys with excess cash getting screwed out there... Educate yourself, and get a little grease under your nails... It will NOT kill you!
Oh, Did I mention I own a 7 figure company, and all my employees think I'm nuts???
Mike
Old Jul 12, 2007 | 07:37 PM
banditlex's Avatar
banditlex is infamous around these parts
It should only take a couple of hours, depending usually on whether the tips you have fit properly. Mine didn't at first unfortunately.
Old Jul 12, 2007 | 07:50 PM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
I pay $200 at a great indy shop in Houston
Old Jul 12, 2007 | 08:20 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Mike thanks for the good info. You give the less mechanically inclined (like me) hope.
Old Jul 12, 2007 | 10:03 PM
fly2low's Avatar
fly2low is infamous around these parts
I swapped out my stock for a Euro as well. Not hard at all.
One tip - use a 2x4 and your floor jack to get the old one out, but especially to get the new one in. Makes it an easy one man job.
Old Jul 12, 2007 | 10:21 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
I'm small enough that I just used a rolling flat work bench (free with jack from autozone) to slide under and just pop it out and roll myself out from under the car holding the exhaust... Its not as heavy as everyone says. I'm 5'11.
Good luck!
p.s - remember if you do it, the straps slide out toward the sides of the car!
Old Jul 12, 2007 | 11:02 PM
emissary's Avatar
emissary is infamous around these parts
I paid $180 (two hour job) to have my Cargraphic installed at my local independent shop.
Old Jul 13, 2007 | 03:34 PM
WOODTSTER's Avatar
It will take about 4 hours to do it your first time.
Not a bad job.
MK
Old Jul 14, 2007 | 11:39 AM
NSD991's Avatar
Thanks for all the replies. I dont think I could do this myself. I took the exhaust to four different places in my small town today. None of them would even take on the job. I guess ill have to drive to a big city to have it done. Too bad the exhaust wont fit in the car. Ill have to take two cars to have this done. i hope its worth it and i like the sound of the exhaust.
Old Jul 15, 2007 | 04:15 AM
Mikelly's Avatar
They don't want to do it because they don't want to take on the liability of having an "Exotic" in there care... I was told this by two shops when I stopped in to inquire about a simple alignment.
Dude, you can do this yourself and I'd be happy to walk you thru it over the phone if necessary. It's truly not that hard... 12 bolts total... 4 each for the turbo flanges (13mm wrench/ Socket), 2 heat shield bolts (10mm wrench/ socket) and the two hanger straps at the rear muffler (mine were 13mm).
A jack and two jack stands, and disconnection of the four 02 sensors under the rear decklid, and you're good to go... 7/8th wrench for the 02 sensors (don't mix them up, but them in the exact same spot each came out of in the old exhaust, same side, same port).
It's truly that simply... couple to three hours... Maybe four at the most... DONE!
PM me if you want to tackle it...
Mike
Old Jul 15, 2007 | 06:07 AM
NSD991's Avatar
Kudos to Mikelly...thanks.
COBB Tuning
Jan 1, 2025 09:02 AM
carwash
Sep 26, 2015 03:11 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
Nissan GTR
Aug 19, 2015 02:11 PM
