Stock vs. Enhanced ECU Flash
Old Jul 24, 2007 | 05:52 PM
SpeedYellow's Avatar
SpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura about
996TT has boost set at .7-BAR?
Mine (purchased used with 14K miles on it) hits 1.0-BAR and I saw it for a brief moment at 1.1-BAR.
What's the horsepower difference with this apparently aftermarket reflash on the ECU (the car is 100% stock otherwise including a factory exhaust).
If HP is around 415 stock, and at .7-BAR then what is it likely to be at 1-1.1-BAR???
Any work done on this?
Old Jul 24, 2007 | 07:34 PM
u cant just compare it like that... what if its a k24 turbo and not a k16 then a k24 at 1 bar will produce more then a k16 at 1 bar. not all ecus are equal... etc... too many other factors... that is why people go to dyno if they really want to know.....
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 24, 2007 | 09:16 PM
Thanks M.
Makes sense to me now. Without knowing more about advance or timing and etc. it would be otherwise difficult to know for sure. Assuming no one swapped the turbos on my car, and I'm running K16's with stock exhaust, then I figured that there would be a "standard" or "expected" horsepower increase vs stock. I do understand the limitations of the K16's vs upgrading to K24's from reading the forum but would still openly wonder if there isn't a formula that could essentially predict, albeit somewhat inaccurately, what the HP gain might be. I know that the X50's and Turbo-S cars came set at 1BAR boost from the factory vs the standard 996TT so I don't worry about the boost level with the K16's but was simply wondering what I might be getting vs a COMPLETE stocker, which mine essentialy is. Perhaps I'll have to find a 4 wheel dyno somewhere in Washington State after all. Other comments very welcome.
SY
Old Jul 24, 2007 | 09:18 PM
Dragon911TT's Avatar
Dragon911TT is infamous around these parts
SY
Are you sure about that... I have an X50 and I only see .8 bar
Old Jul 24, 2007 | 09:29 PM
Interesting... Had a couple of P-Car dealers tell me it was 1.0. Seattle, and Scottsdale. He/They may have been referring only to the Turbo-S.
Old Jul 24, 2007 | 09:41 PM
justinmm2's Avatar
justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !
Most chips claim 75-ish hp and lb-ft. Give or take a bit (I've seen 85 claimed before..) on a K16 996TT
Old Jul 24, 2007 | 09:47 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I've seen claims anywhere from about 60 to 100hp. You can check some of the sponsers websites to see what their stage one flashes add. That will give you an idea of what you might have.
Old Jul 24, 2007 | 11:17 PM
Perfecto.
Feels like around 450-max but again.... impossible to tell without a dyno test to prove it. Like so many things in life.... we like to think it's bigger than it really is... have to measure it to be sure.
Old Jul 25, 2007 | 06:01 AM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
The x50 and Turbo S are the same set up. They see .8-.9 bar, a chipped k16 w/diverters (you should check to see if you have these) is claimed to be 70-85hp difference. Also, they say that they generally gain more in tq than HP.
Old Jul 25, 2007 | 07:30 AM
WOODTSTER's Avatar
No stock 996TT or GT2 had factory 1.0 boost, none.
Modded ECU cars run 1.0 to 1.1 bar typically and combined with a good exhuast that flows better expect to go from 415 to about 480-490 on
a K-16 car. K-24 car go from 444 to about 515-530 hp.
IMHO
60-130 stock car == 12.5
60-130 ECU/exhuust 10.5 -11.0 seconds (k-16 car)
MK
Old Jul 25, 2007 | 08:32 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
IMHO
MK
Thanks! My conversations with tuners that are not to be taken as dogma or as official data suggested a case of 35hp/0.1bar increase for the best tuning. I won't go into which tuner is best....they all have various levels of focus that reflect their philosophies. I am biased (see my signature), but many sponsors of this board do great work.
Wooosh's dyno runs on the TJW exhaust mod show a stock k16 car with just the software from UMW for a reference that is easy to find....just fyi.
Different brands of dyno's, days, heat, etc. make doing science in the regard hard to impossible. Reputable tuners all have in-house dyno's it seems. IA, Sharkwerks, and UMW are on my list as they have been kind to me and have good reputations on this and other forums. There are many others...these are USA based and ones who have been kind to me.
Good luck with the project(s)!
It is a lot of fun. The ECU flash was the most amazing change I have ever seen in a car....just amazing what it did.
Old Jul 25, 2007 | 08:40 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Different brands of dyno's, days, heat, etc. make doing science in the regard hard to impossible. Reputable tuners all have in-house dyno's it seems. IA, Sharkwerks, and UMW are on my like. There are many others...these are USA based and ones who have been kind to me.
JCB, the 35 hp per .1 bar is not accurate in this context. That is what Mark can achieve per .1 bar with a capable fuel system and GT35 turbos. The gains on a smaller turbo will be much less per .1 bar since they are flowing much less air at an equal pressure. KPG
Old Jul 25, 2007 | 09:00 AM
I stand corrected....My guess on my car is that it mirrors Wooosh's dyno data....so 20-30hp/0.1bar....but torque is really impressive on the ECU and is something that is just amazing to feel....hard to describe.
JB
Old Jul 25, 2007 | 09:04 AM
KPG's Avatar
KPG
JB
I agree on that score. The added tq makes the car feel so much more respnsive, and you and I know that our guy likes tq...lots of it KPG
Old Jul 25, 2007 | 10:19 AM
john revis's Avatar
john revis is infamous around these parts
flash = money well spent, and the best return on the never ending mods.
