Who has used TOYO Proxes T1R 315 25ZR19 98Y?
Old Aug 11, 2007 | 09:36 AM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
They only cost about $300/piece.
Thinking about giving them a try.
Old Aug 11, 2007 | 01:12 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
I've got them - only have ~4000 miles on them so far.
No track, just commute - previous was MPS2s.
What do you want to know?
Old Aug 11, 2007 | 01:29 PM
BlackBear's Avatar
What are you running on the front?
I have Michelin PS2 in 235 35 19 in the front and I have PSM kick in much sooner now with the Toyos than I used to with 315 25 19 Contis in the back.
Old Aug 11, 2007 | 03:40 PM
RiA's Avatar
RiA
I have same Toyos in 235/35/19 up front and no issue with PSM and early engagement.
Old Aug 12, 2007 | 09:45 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I use them, great tire for the price but they are not as good as the Pilot sport.......Again great tire for the price.
Old Aug 12, 2007 | 09:58 AM
BlackBear's Avatar
Do you have the same Toyo on the front? If not what do you run in the front?
Old Aug 12, 2007 | 10:48 AM
Dr_jitsu's Avatar
BB,
I highly recommend the Nitto (sister company to Toyo) 01's.
Old Aug 12, 2007 | 12:13 PM
kilrgt's Avatar
Yes same tire
Old Aug 12, 2007 | 12:42 PM
john rice's Avatar
john rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to behold
When you mix and match, you also have to deal with how old the particular tires are and how that may/may not be affecting the handling. Unless all 4 tires are same spec/age/treatment it can be a guessing game. Also, don't forget that some new tires require some break in before they are optimum. More than once in the past I bought street tires that were scary for about 100 miles but then worked very well. [Back in the day I would go out and run them really hard and scrub them in in about 30 minutes.... but I'm not crazy anymore. Oh, and my tires actually somes get too old and hard before I wear the the tread out. I never would have believed!]
JR
Old Aug 12, 2007 | 02:47 PM
Dirty Mac's Avatar
Dirty Mac is infamous around these parts
Funny I had the exact same set up. DON"T DO IT. I was at a two day track day. Midway through the first day I noticed that my PS2 rears were showing some cord. The only replacements I could find right away were the Toyos. I had them installed only in the rear. The next track day the PSM was going off all over the place. I thought that the PSM was faulty so I turned it off. I then experienced my first and second high speed wipe outs . Bad idea. Moral of the story: Do not mix and match. (actually the moral of the story should be: if you are going to turn off your PSM, lower your speed and get an instructor in your car) The different diameters of the tires will set off the PSM at every turn which I am sure is not too good for car.
I immediately ordered a set of Toyos for the front. I've tracked with them on. They have no where near the grip of the PS2s but they reach their limits smoothly which makes for a fun set up at the track (but obviously not the fastest). They cut through water very well but I can't comment on their wet braking ability. They also seem to be wearing very well. Cheap tires that last long.
titannero
May 20, 2016 08:12 AM
drug delivery
Oct 24, 2015 11:04 PM
Turbo3.6
Sep 18, 2015 11:10 AM
wastedyolk
Sep 17, 2015 11:57 AM
