Evoms GT700, more linear-stable then GT640 ?
Old Sep 6, 2007 | 01:23 PM
porschenaround's Avatar
porschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of lightporschenaround is a glorious beacon of light
My original k16 oem stock porsche 996tt was dammm stable and linear on a road-course track. When in a turn, i could be half throttle down and it was consistent and didn’t fluctuate power.
Now, i had my gt640 kit for about a year, great full throttle power, however, if you try to go halfway throttle over 4k rpm its unstable, inconsistent, erratic.
Did anyone here have the 640 then go to 700 ? Did the Hitachi mafs make a difference in this regard. ?
Old Sep 6, 2007 | 02:03 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Interesting perspective that I would like to hear others response as well.
I'm about to endeavor the GT640 or 700 myself - would be interested to hear what others have to say from their experiences.
Rich
Old Sep 6, 2007 | 02:15 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
I believe the difference between 640 and 700 is the fuel system. Turbos are the same...
Old Sep 6, 2007 | 03:13 PM
SlowMotion's Avatar
SlowMotion is infamous around these parts
My 640 was the same.. almost on off, no real control in the middle. UMW stg 2 ZC gives you complete control, it's almost like driving an NA car.
Old Sep 6, 2007 | 04:55 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
the old MAF for GT700 was stable. the new Hitachi MAF is *very* erratic as you describe, in 4k rpm+ at mid boost levels - almost to the point of being dangerous. in a curve, where you may not be full throttle, it will start acting erratic, bucking almost, and you can imagine how that could lead to dangerous situations.
the new MAF is *very* fast but this and my LWFW stalling problems are not making me very happy. while i don't want to give up the speed, i may revert back to the old MAF.
- chuck
Old Sep 6, 2007 | 05:10 PM
TTdave's Avatar
TTdave is infamous around these parts
Sounds like some tuning tweaks still needed with the new MAF?
Old Sep 6, 2007 | 05:34 PM
Zippy's Avatar
I went from the 640 to the 700. I thing I hold the record for fried MAFs. The 640 is a little problematic, particuliarily with the Bosch MAF (which can only read air flow up to 480 HP). The new H=-MAF has full resolution to redline and the file is much more refined. The compensation (IE RICH TUNING) required with the BOSCH MAF is no longer an issue. The H-MAF provides WAY smoother off idle stability and a much more accurate air/fuel mixture at WOT (doesn't need to make adjustments from the 02 sensors as the MAF can properly meter the air). This = more power and superior drivability. The fuel system upgrades in the 700 kit make me feel much more comfortable.
Old Sep 6, 2007 | 05:43 PM
carendt242's Avatar
Zippy, you don't have problems w/ 4k+ rpm and mid-boost levels? My car bucks and becomes quite violent when i begin to lift the gas slightly (if memory serves me correct.) It feels like a tuning problem but I was told the new MAF acts like this.
- chuck
Old Sep 6, 2007 | 06:57 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Chuck,
Boy oh boy, SO I am not the only one!...I have exactly the same problem, I have had this issue since installing the new Hitachi MAF and software. You are spot on, it is bloody dangerous at times going into corners..
Chuck, I am PMing you about this.
BBB
Old Sep 6, 2007 | 09:15 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
This is not good news. Looks like EVO fixed one problem but caused another. Who else has the new HMAF + SW and having problems?
Can someone from EVO chime in?
Jag
Old Sep 6, 2007 | 09:30 PM
Dr_jitsu's Avatar
I think you are experiencing turbo surge. I used to get it a lot on my set up (which was similar to the GT640). I since installed the Proto Fuel system and the surge is reduced.
Old Sep 6, 2007 | 09:35 PM
carendt242's Avatar
Dr-jitsu, it does feel like turbo surge (or what i think turbo surge feels like) but there are no noises. In my Supra, i had a similar feel and it was errors in the fuel map.
I'm not sure how a fuel system would solve a turbo surge problem; it's not related afaik.
- chuck
Old Sep 7, 2007 | 12:06 AM
Zippy's Avatar
- chuck
Chuck - I do get this at times. When I constantly drive the bag off the car it seems to adapt and not do it. Periodically whe I simple think about getting off the gas it feels like power dissapears 100%. I've had this several times. I find when I'm driving aggressively, it seems to not really happen at all? Strange!
I had a track day for the first time in a long time last month in Calgary. Never happened once.
I'm glad to see it's not a "Canadian gas" issue. You ever get any codes?
Old Sep 7, 2007 | 12:17 AM
Interesting info... why doesnt someone call or email Todd and ask. They usually make improvements as time goes by.
I can tell you all that a proper MAF is the solution to most tuning issues.
regards,
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 7, 2007 | 12:19 AM
Zippy's Avatar
Mark...
Who's Inga?
