View Poll Results: How long do you let it warm up?
Get in and go!
25.49%
Less than a minute
14
27.45%
Between 1 and 2 minutes
17.65%
Between 2 and 5 minutes
9.80%
Until the oil temp reaches normal operating temps.
10
19.61%
Voters: 51. You may not vote on this poll
Engine Warm Up
Old Sep 10, 2007 | 09:39 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
i was under the same impression, get in and drive, take it easy for the first 2-3 minutes, then let her rip.
Old Sep 11, 2007 | 02:47 AM
wirx's Avatar
wirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud of
in cold winter I wait about 2-3 minutes,summer ~10sec, but never go hard when motor is cold
Old Sep 11, 2007 | 04:09 AM
Scott W's Avatar
Scott W is infamous around these parts
I am sure sure Porsche states not to idle because it means the catalytic converter will not start to operate, and also the gearbox, and drive line oils will not warm up. I would, however idle for 1-2 minutes, then drive under 3000-3500rpm, as well as under little load, until the engine is well into operating temperature. Then drive it hard, like its meant to be!! . Then idle for a bit before shut down.
Old Sep 11, 2007 | 06:44 AM
Lounge Lizard's Avatar
Lounge Lizard is infamous around these parts
Originally Posted by vanboost
I crank and go, but short-shift at 3k until the temps are stable...then it's go-time. This is a real tease for me as I am onto the freeway in about 2 minutes depending on work.
On the way home, I start to really baby the car for the last few minutes. I have considered a turbo timer but it's not super-necessary for me.
If you're the type to turn the key and punch it, remember: your Turbo is wishing it could rouse you out of bed at 3am, whip you through a few wind sprints and tear both your hamstrings.
Wot he said , I let it go but keep to 3k rpm until she's warm and always take it easy for the last minute or two of the journey.
Jul 29, 2019 11:13 AM
henryr
Sep 24, 2015 08:22 PM
away
Sep 4, 2015 12:30 PM
ritchrwi
Aug 29, 2015 08:27 PM
