Where is the FPR
Old Aug 28, 2007 | 07:33 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
Where is the FPR
Can anyone give me a hint where to find the FPR on an '02 GT2?
Old Aug 28, 2007 | 08:04 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
On the right side look for the air pump (the round black thing left of center in this pic):
Remove that and you will see the fuel pressure regulator (dead center in this pic):
I've been planning to write a DIY for this - maybe now's the time!
Jeff
Old Aug 28, 2007 | 08:10 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Just give him a hint..not exactly....geez!
Old Aug 28, 2007 | 08:48 PM
Bodybag's Avatar
Holy cow!!! Thanks!!!
Old Aug 29, 2007 | 06:37 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Getting the retaining clip out of the FPR requires some ooomph....Just DO NOT drop it. It will fall somewhere that is impossible to get. Ask me how I know. Good luck.....
Old Sep 5, 2007 | 04:32 PM
Bodybag's Avatar
Finally got around to changing the FPR today. Easy job that will take about 40mins to and hour. The pictures that were provided are very helpful, thanks!
I spent 20mins or so looking for a shortcut, but the bottom line is that the air pump needs to be pulled from the mount and moved out of the way. In order to do this you need to remove the 2 10mm bolts that are screwed into the intake plenum, remove the hose from the bottom of the air pump, and unplug the to wire harness connections. At that point just take the oil fill tube away from the pump bracket and move the pump forward and rotate it to the side. Once you've done that you can see the FPR and you'll have access to it.
My retaining clip was in upside down, so it was a ***** to get out without dropping it. But I reinstalled it facing down so if I ever need to get it out again it will be easy. Once the clip is out, pull the FPR from it housing. I used a little dab of motor oil on the new one to help it slide back in (it's a tight fit) and then reinstalled the clip.
The rest of the stuff goes back together in 1/2 the time it takes to get it out.
Good luck to the DIY guys
Old Sep 5, 2007 | 08:06 PM
MidnighTT's Avatar
I did drop the upside down clip (actually, it went TWANGO), but luckily my magnetic retriever snagged it (I couldn't see it from any vantage point, even with my collection of mirrors-on-a-stick).
OTOH, the aluminum nipple from my Forge diverter valve has found a new home on top of the engine somewhere.
Jeff
Old Sep 6, 2007 | 12:05 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
My tuner has told me that it is not really mandatory to keep that air pump on the engine. Would anyone disagree?
Old Sep 6, 2007 | 07:53 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
You will get a CEL and fail emissions testing. The air pump lowers emissions during cold starts. A talented programmer can modify the DME code to ignore this, avoid CELs and pass emissions.
Old Sep 8, 2007 | 02:56 PM
PorschePhd's Avatar
You can also run the Euro program or like the China program. They do not have the smog pumps. Anyone with a PS2T or PIWIS can change the program in the car to reflect a different country.
Old Sep 11, 2007 | 08:23 AM
Member
Cool. That's good to know. Will doing this alter any previously done performance programming?
Bobbyfali
Jul 31, 2017 01:28 AM
uurfantasy
Sep 23, 2015 09:10 AM
gpt817
Sep 8, 2015 10:21 AM
orbelo
Aug 30, 2015 12:26 PM
