View Poll Results: How long do you let it warm up?
Get in and go!
25.49%
Less than a minute
14
27.45%
Between 1 and 2 minutes
17.65%
Between 2 and 5 minutes
9.80%
Until the oil temp reaches normal operating temps.
10
19.61%
Voters: 51. You may not vote on this poll
Engine Warm Up
Old Sep 10, 2007 | 05:08 PM
sdorn's Avatar
sdorn is infamous around these parts
Engine Warm Up
I drive my 996TT everyday as my daily driver. I almost always let the car run for 2 to 5 minutes so the engine will warm up before driving off, and in the morning sometimes I let it run for 10 minutes. I find that if you don't at least let it run for 1 or 2 minutes, the throttle is very unresponsive and the engine hesitates.
My question is, how long do you guys normally let your car warm up before taking off? Do many of you just get in and go, or do you always let it idle for a while first?
Old Sep 10, 2007 | 05:20 PM
fastoc996twint's Avatar
fastoc996twint is infamous around these parts
i drive mine daily, only warm it up alittle.. less than one minute.... i do however drive slow at first for the first few miles..
Old Sep 10, 2007 | 05:27 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
I think I read in the manual it says not to sit there idling upon startup. Crank the car and go. I do stay off of boost utill temp is up to normal. I have heard that water temp will come up before oil is acutally up to temp. May be a good idea to allow a fuz extra for oil to warm up before boosting it hard. Anyone else agree with this?
Old Sep 10, 2007 | 05:30 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Mine is a DD as well ... I start it up ... and when the rpm needle dips after a minute or so, then I go ... as with y'all I keep off of boost until optimal operating temp ...
Old Sep 10, 2007 | 05:55 PM
wross996TT's Avatar
Originally Posted by silver
I think I read in the manual it says not to sit there idling upon startup. Crank the car and go. I do stay off of boost util temp is up to normal. I have heard that water temp will come up before oil is actually up to temp. May be a good idea to allow a fuz extra for oil to warm up before boosting it hard. Anyone else agree with this?
This is correct (RTFM). You need to warm up more than just the oil. Porsche recommends start and GO...I do not get on it until after about 5 minutes
Old Sep 10, 2007 | 05:59 PM
sdorn's Avatar
This is good to know. I guess I will stop letting it sit so long after cranking it. Do you guys notice the hesitation after you first start it, though? I have a left turn to make across a busy intersection when I leave my subdivision in the morning and I am likely to get hit in the side if the car hesitates while I am pulling out.
Old Sep 10, 2007 | 06:01 PM
DrivItLkUStolIt's Avatar
DrivItLkUStolIt is infamous around these parts
I get in and go but do not get on it until the car has been at temp for few minutes. Cool down once I get into the about a mile from home, I mellow out so I can just turn it off when I get home. If it happens to be a really hot day I will let it sit for a minute before I turn it off
Old Sep 10, 2007 | 06:05 PM
Divexxtreme's Avatar
That's exactly what I do. I also never go WOT unless the car has reached normal operating temps.
Old Sep 10, 2007 | 06:35 PM
TT Tommy's Avatar
TT Tommy is infamous around these parts
under 3,500 rpm until close to 180 deg
30 second cool down at idle if last few miles were mellow. 1 min cool down if hard driven before parking
Old Sep 10, 2007 | 07:42 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
I think Porsche recommends start up and go...but do not exceed 4000 RPM until engine reaches operating temp. Pretty much what others are saying.
Old Sep 10, 2007 | 07:57 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I let my warm up for a few seconds and then drive it easy until it fully warms up.
Old Sep 10, 2007 | 08:22 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
I start and go, then drive like a little old lady until normal operating temp -- after that, then I go WOT as often as I can.
Old Sep 10, 2007 | 08:57 PM
justinmm2's Avatar
justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !
I'm gentle until the oil *pressure* is below 2 at idle.
I see 0.1 bar while it's warming up occasionally. I figure a little boost can't hurt. It's so hard not to sometimes
Old Sep 10, 2007 | 09:02 PM
vanboost's Avatar
vanboost is infamous around these parts
I crank and go, but short-shift at 3k until the temps are stable...then it's go-time. This is a real tease for me as I am onto the freeway in about 2 minutes depending on work.
On the way home, I start to really baby the car for the last few minutes. I have considered a turbo timer but it's not super-necessary for me.
If you're the type to turn the key and punch it, remember: your Turbo is wishing it could rouse you out of bed at 3am, whip you through a few wind sprints and tear both your hamstrings.
Old Sep 10, 2007 | 09:36 PM
TT Tommy's Avatar
couldn't have said it better!!
tw
