Altitude adjustment
Old Sep 13, 2007 | 04:15 PM
Superfly's Avatar
Superfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant future
Altitude adjustment
Note it says ALTITUDE, not attitude.
Just wondering, I'm at about 2200 ft. Will my Turbo make proportionately more power than a normally aspirated car vs the same two cars at sea level.
ie - I've got 444 hp, car x has 450 hp. These are sea level measurments right? You lose power at alititude, but I've got turbos, so I lose less. So at altitude, do I now have MORE power than car x does?? Is there some way to calculate relative horsepower losses for altitude and the differences therein with Normally aspirated vs turbocharged cars? If it's a big difference, does that mean the Denver guys are getting a really cheap power boost (wouldn't be a bad reason to move there )
Old Sep 13, 2007 | 05:24 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
you will lose power in altitutde but much less then an quivalently HP rated NA car would lose...
Old Sep 14, 2007 | 12:59 AM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
I've noticed the difference in the car when I was in Vegas as compared to So Cal, but there was more of a difference in my M3 than the TT.
Old Sep 14, 2007 | 08:07 AM
Superfly's Avatar
Code:
Do you mean you felt a greater loss of power in your M3 or in your TT?
Old Sep 14, 2007 | 08:31 AM
KoalaCowboy's Avatar
KoalaCowboy is a name known to allKoalaCowboy is a name known to allKoalaCowboy is a name known to allKoalaCowboy is a name known to allKoalaCowboy is a name known to allKoalaCowboy is a name known to all
There are a lot of variables that come into play here. Yes, for 'average' conditions, you will lose some power at altitude due to the thin air (air density). However, if you are at altitude and on a cool day, you will be able to compress the available air more, so the HP loss will be less.
TO calculate the the 'amount' of horsepower compared to normal, you can use this tool (which is provided AS IS, not written nor created by me):
http://wahiduddin.net/calc/calc_hp_dp.htm
Old Sep 14, 2007 | 08:36 AM
Superfly's Avatar
KoalaCowboy.
Thanks, that's what I was looking for. Now if there is something that calculates the same for Turbocharged engines, I'll be starting to figure this out!!
Cheers
Old Sep 14, 2007 | 09:48 AM
Originally Posted by Superfly
KoalaCowboy.
Cheers
Superfly, I will keep digging (being the Techno-geek that I am) and see if I can either find one specific to Turbos OR reverse-engineer the logic in the code and see if I can include the BOOST (x.x BAR) into the algorithm.
Ciao!
Old Sep 14, 2007 | 10:10 AM
Boulder GT3's Avatar
Boulder GT3 is infamous around these parts
As mentioned earlier, many variables in power loss at altitude and a turbo does do better than normally aspirated but there is still loss. A VERY general guideline is that with similar air conditions a normally aspirated motor will lose 3% per 1000' and a turbo will lose 1.5-2%.
A stock C6Z06 will be roughly 1 second slower through the quarter in Denver vs. good dry dense air at sea level.
Old Sep 14, 2007 | 10:55 AM
Code:
Yes, the noticable loss of power was greater in the M3 than it was in the TT going from sea level to 2,500+ feet above sea level.
davetherave
Bentley
Sep 16, 2015 06:30 AM
