**need Help With Remote Key**
Old Nov 14, 2007 | 01:37 PM
snpdesigns's Avatar
snpdesigns is infamous around these parts
I Have A 99 C2 And My Remote Key Doesn't Work.
I Replaced A Battery And Still Nothing.
I Can Open It Manually.
Thanks For Any Information.
Jin
Old Nov 14, 2007 | 05:10 PM
Dscott's Avatar
Dscott is infamous around these parts
I think my 2000 C4 has the same single-button remote as yours. It began to fail with shorter and shorter reception ranges until it finally stopped working all together. New batteries made no difference. I was able to have the dealer replace the transmitter inside the key hood for $267. He had the part in stock and it only took them about 20 minutes.
As part of this fix I also made the mod to the car's remote antenna length. Now I can consistently lock/unlock from 40~50 feet away; sometimes much further.
Old Nov 14, 2007 | 06:18 PM
ggulik's Avatar
ggulik is infamous around these parts
There's a mod to make the remote work at longer distances?
Is it a DIY type project?
Old Nov 15, 2007 | 08:23 AM
snpdesigns's Avatar
Thanks!
Looks like I need a new key.
Old Nov 15, 2007 | 01:58 PM
djantlive's Avatar
try inserting the battery backwards w opposit polarity and see if any improvement. most likely a dealer visit tho
Old Nov 15, 2007 | 08:17 PM
wwboater's Avatar
wwboater is infamous around these parts
Try pushing the button on the key while turning it to the start position in the ignition. Hold for 5 seconds and this will reprogram your car to your key.
Old Nov 16, 2007 | 03:37 PM
auto-xr's Avatar
auto-xr is infamous around these parts
Has this actually worked for you?
Old Nov 16, 2007 | 04:38 PM
snpdesigns's Avatar
I'll Try It Tonight.
Thanks!!
WheelsupZR1
Oct 20, 2015 08:36 PM
The_Orange
Oct 3, 2015 08:23 AM
longboarder
Sep 12, 2015 12:55 AM
lokmeup
Sep 9, 2015 09:24 PM
