Convertible top repair
Old Nov 18, 2007 | 10:22 PM
jkb's Avatar
jkb
jkb is infamous around these parts
howdy all...
my 996 soft top is in need of some repairs. as you can see from pictures, the wire which runs on the very edge of the top snapped at the very bottom (only clip is left in place):
because of the wire not pulling on the side of the top, it does not end up sitting inside the grove properly:
it looks like i should be able to pull the old cable out and put a new one in. the questions are:
1. is this an easy DIY project? (looks like it)
2. i could not find how the wire is secured on the opposite end.
3. any special tools i might need?
TIA...
Old Nov 19, 2007 | 08:34 AM
daytrader's Avatar
daytrader is infamous around these parts
Check with Renntech for DIY. They might have the answer. If not check this co. for more info. they're specialize on European soft tops. http://www.gahh.com/
Old Nov 19, 2007 | 09:55 AM
djantlive's Avatar
i don't like to deal with the top. if you want to take it to a shop, premier upholstry in santa clara is good.
Old Nov 21, 2007 | 10:10 PM
nicolaasdb's Avatar
nicolaasdb is infamous around these parts
I got the same problem and haven't found a solution yet....got to get it done soon, because it bugs the hell out of me when something doesn't work properly
Old Nov 24, 2007 | 03:12 PM
Russcan's Avatar
Russcan is infamous around these parts
Good luck with the fix. Keep it posted how you go about it.
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
oo7
Sep 10, 2015 08:08 AM
zuman
Sep 3, 2015 08:27 AM
AdamNoone
Sep 3, 2015 04:12 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
