how to change the oil seperator
Old Apr 1, 2009 | 04:33 PM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Check here: http://www.planetporsche.net/cayman-...ere-smoke.html
Exactly what I'm talking about...Are we on the same page 1999?
Old Apr 1, 2009 | 04:47 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
What does that link have to do with blowing smoke out the tailpipes? There is one purpose of the baffle and ONLY one. That is to reduce the possibility of the pickup tube sucking air. Just because some shop wrongly advertises the benefits of a product does not make it work.
Old Apr 1, 2009 | 05:00 PM
RocC4S's Avatar
Did you read this part from the link:
"I've had the same problem but usually after the session is over and the cars been sitting with the engine off, when you restart you get a cloud of white smoke. Do a search on the forum, cos I know I've seen this before here, I even think there's a solution with some form of oil baffle system from Motordrive or something. Never happened to me on track and I was never blackflagged. Was it a road course or an Oval? I could see the sustained G's on an Oval causing this."
All I know is, I can speak from personal experience on this. Check with C2MOJO, same thing happened with his car, same DE day, same common problem...look into it. I'm done.
Old Apr 1, 2009 | 05:28 PM
Redridge's Avatar
x51 oil pan is under the car... keeping the sloshing oil down to a minimum so that the oil can be sucked in by the pickup... then it is fed to the engine via the oil pump. The pan and the oil it contains is outside the engine... all the oil issues you are talking about is inside the engine.
The problem with the caymans is that it can pull serious G's around a corner...and the stock aos is short... oil can creep up the aos column and gets injected into the intake.... All of this oil is coming from the insides of the engine and not the pan... the motorsport aos is actually a 996 part that is way taller with less chance of oil creeping up the column of the seperator.
The smoke at start-up is very common for a horizontal engine layout... the oil has nowhere to drip down... and gets stuck in cylinders and such... very common on the track to see this esp if the engine was shut down w/o letting it idle for a minute or so...
With that said, the x51 oil pan is a great upgrade if you track your car... it holds more oil in the baffles than stock one...
Old Apr 1, 2009 | 05:32 PM
It's all a coincidence. Just think about what an oil pan is for. Without the pickup tube, unless you were driving your car on a 90 degree bank, no oil would ever get to any part of the engine....with or without a baffle.
Old Apr 1, 2009 | 07:58 PM
blown996's Avatar
blown996 is infamous around these parts
good point...
Old Jul 24, 2009 | 04:56 PM
Jag's Avatar
Jag
Jag is infamous around these parts
How can you tell if oil air separater has failed
I have a 2008 carrera S 5,000km, blowning crazy white smoke from exhaust, how can you tell if the oil air separtor is failing and not the headgaskets.....coolant is low....
THANKS ALLOT !!
Old Jul 24, 2009 | 08:18 PM
Redridge's Avatar
THANKS ALLOT !!
2008 c2s.... that's pretty new. Did you check your oil level, to high will cause smoke? crap... you dont have a dipstick.
smoke and even a whistling noise is the symptoms of a bad seperator....
Old Jul 24, 2009 | 10:18 PM
Jag's Avatar
Jag
air oil sep
LOTS & LOTS OF SMOKE!!!!! haven't heard a whisling sound.....could be a headgasket you think, very odd if it is.... When the O/A failing does it leak coolant into the cylinders???,,,,, I fear the worst and that is the headgasket failing.....The smoke could be either the headgasket or O/A sep.....any other thoughts..
thanks
Old Jul 24, 2009 | 10:20 PM
Jag's Avatar
Jag
its a coolant white smoke not oil. and the coolant level is down low.... the engine does run smooth at cold idle, which if the HG was to go I would think it would run rough......right?????
Old Jul 25, 2009 | 10:09 AM
Redridge's Avatar
you need to take that in.... hopefully it is the head gasket and not an intermix issue. Do you see coolant/oil (damn you dont have a dipstick) mixed together. Could be oil cooler, cracked head, or gasket.... bring it in... it should be covered under warranty.
Old Jul 26, 2009 | 03:38 PM
Jag's Avatar
Jag
rebuilt, no warranty.......it runs smooth still so I;m hoping its the air oil sep.
Old May 9, 2010 | 05:10 PM
gixxer638's Avatar
gixxer638 is infamous around these partsgixxer638 is infamous around these partsgixxer638 is infamous around these partsgixxer638 is infamous around these partsgixxer638 is infamous around these parts
your step eight is impossible what car do you have i put the motorsports aos but that did not change things that much
Old May 10, 2010 | 12:55 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
I'm sure I need a new AOS soon. I just can't wait to see how much they want expecially being a tip.
Old Jul 8, 2010 | 01:02 AM
0100's Avatar
0100 is infamous around these parts
Bump!
Thanks for the write up.
Plan on doing the AOS soon.
I have a 99 C2.
Any other parts you guys recommend replacing while doing this job?
