Clutch "click"
Old Feb 28, 2008 | 07:40 AM
mpickup's Avatar
mpickup is infamous around these parts
Clutch "click"
I understand the "click" when you reach the very end of the clutch being depressed is normal, but it's driving me slightly batty . I never had this in any of the numerous cars I've driven in either the US or UK. To make matters worse, there's a clutch squeek. So every time I change gears, its "squeek, click, click, squeek"!!! Can anything be done?
Thanks,
M
Old Feb 28, 2008 | 10:20 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
I can't help with the click, since that's normal and due to the activator switch on either end of the pedal travel. I had the squeek too and a little spray from WD40 on the pedal hinge and the piston shaft eliminate the problem. If the click-click bothers you, turn your radio up. that's what I did. ; )
jp
Old Feb 28, 2008 | 10:33 AM
mpickup's Avatar
OK, I'm guessing the WD40 thing is something that cannot be done from inside the cabin? As you can guess, I'm not very handy with my own car repairs. I have to visit the dealer for something else so maybe they can quickly take care of this.
Old Feb 28, 2008 | 11:28 AM
JoelPirela's Avatar
I went to the dealer for the clickity-click. They say is normal.
Grab a can of WD40 and get under the dash of your car. with your fingers, follow the pedal towards the pivot part at the top. Spray a little there, then, look for the piston looking part that goes to the firewall (from the same position, you will see) and spray there too. It helps if you press the pedal with your hand while doing it. Lightly spray...
joel
Old Feb 28, 2008 | 11:30 AM
mpickup's Avatar
Excellent, thank you. I'll give it a try.
Old Feb 28, 2008 | 02:09 PM
996THIS's Avatar
Member This
996THIS is infamous around these parts
I had the same issue and it was a clutch fork...covered under warr.
Old Feb 28, 2008 | 02:13 PM
JoelPirela's Avatar
the clickity-click or the squeek?
Old Feb 28, 2008 | 02:24 PM
996THIS's Avatar
Member This
Its more like a creaky sound when stepping on the clutch
Old Feb 28, 2008 | 02:48 PM
porsche4391's Avatar
porsche4391 is infamous around these parts
yeah thats not normal lol..but the click is for sure...means its good to be started!
Old Feb 28, 2008 | 02:54 PM
IhuangerI's Avatar
IhuangerI has a spectacular aura aboutIhuangerI has a spectacular aura about
i actually really like the click sound =)
Old Feb 28, 2008 | 04:19 PM
c2mojo's Avatar
c2mojo is infamous around these parts
I used dry silicone spray and it worked great.
Old Feb 28, 2008 | 04:32 PM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
If you shift fast enough, you can time the click with a snick.
Old Feb 28, 2008 | 04:33 PM
silversurfer22's Avatar
silversurfer22 is infamous around these parts
The click is the activator switch which cannot be help. The squeeking sound is the clutch pressure spring. I all together removed the whole thing to make the clutch stiffer. Best free mod I'll done. There's a thread on rennlist.
Old Feb 28, 2008 | 05:28 PM
RobynC's Avatar
Porsche Chick
RobynC is infamous around these partsRobynC is infamous around these parts
Just stop short of the click...you don't have to depress the clutch all the way to the back to be fully engaged.
Old Feb 29, 2008 | 08:02 AM
mpickup's Avatar
Again, thank you for all the useful information.
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
Blue Chip
Sep 10, 2015 07:07 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
