996 suspension mod help
Old Jul 10, 2004 | 06:27 AM
fasteddie99's Avatar
fasteddie99 is infamous around these parts
Question 996 suspension mod help
I have a 99 C2 whose suspension I'd like to modify. Lowering would be an added bonus. Don't want to spend PSS9 money however.
Thinking about RoWMO30 from carnewal.com...(are they OK to deal with?)
Comments? suggestions?
Old Jul 10, 2004 | 06:56 AM
Don Relentless's Avatar
Don Relentless is infamous around these parts
wait till you can get coilovers, springs$300 installation and alignment $500. $850 bucks for something you will need to do over eventually. i do not recommend just a spring swap. a huge difference in performance over a coilover. if you do just do the springs, you will need anti sway bars as well. just my opinion.
Old Jul 10, 2004 | 10:56 AM
stiles_s's Avatar
stiles_s is infamous around these parts
ROW M030 isn't just springs, it's springs, dampers and swaybars. It's a balanced system tuned by Porsche.
The benefit you get from an adjustable coilover like the PSS9 is height and damping adjustability.
And, yes, Carnewal is great to deal with.
Old Jul 11, 2004 | 12:34 PM
Greg L.'s Avatar
Greg L. is infamous around these parts
You can also check the 996 suspension area of Rennlist.com for a writeup of different options.
http://tech.rennlist.com/
Old Jul 12, 2004 | 12:05 PM
I was looking at Bilstein sport shocks shocks with either Eibach or H&R springs...
Old Jul 15, 2004 | 03:36 AM
If I were to go with PSS9s, where is the cheapest place to get them? Also, who should I have do the install and alignment in the greater Sacramento/SF area?
Old Jul 15, 2004 | 09:17 AM
Kevin M's Avatar
Modaholic
Kevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond repute
It all depends what your trying to achieve.. I think one problem here is that most of the guys that have PSS9's or H&R Coilovers will of course recommend them. But until someone says I drove a car that had Sport Shocks with lowering springs and then I jumped in a car with PSS9's and can see a day and night difference.... then I will believe them... Mostly we all have opinions based on some personal experience.. so take all of the so called facts and make your own decision. Sometimes you get what you pay for and sometimes its overkill for what is trying to be accomplished. From my investigating lowering springs are about $300 and Bilstein Sport shocks are about $700.. If your going for a lower look and a slightly better ride I would go this route. Install and alignment shouldn't cost more then $500-$600 Now if you track the car often and your looking for the best handling suspension then I would certainly save and spend the extra $800-$1k on PSS9's.. this of course is just my $.02, I have yet to modify the suspension on my 996. although I have had a set of Gemballa springs sitting in my garage for the last year
Old Jul 15, 2004 | 10:43 PM
Kevin M. : You've nailed my dilemma on the head. I want the car lowered a bit. My driving will mostly be spirited street drives. I have yet to decide about trackdays. I do those on my bike, so I know that they are hard on the machine...Soooo, I'm leaning towards a MATCHED shock and spring kit. Will I need aftermarket sway bars as well?
Old Jul 16, 2004 | 03:50 AM
carcrazee's Avatar
carcrazee is infamous around these parts
I have the M030 sport suspension on my C4. car is 3/4" lower on front and 1/2-5/8" on the rear. rides better than stock set up. Got them from Gert @ Carnewall.. set up came w/ f/r sway bays.
took it to the track last weekend;slight improvement over stock on cornering. overall, I am happy w/ it. If i was to push the car harder or do more than 3 tack event per year, I probably go w/ the PSS9.
Old Jul 16, 2004 | 04:59 AM
What shocks should one use with the M030? My stock shocks have 42K on them and are ready to be tossed...
Old Jul 16, 2004 | 12:52 PM
KLZ's Avatar
KLZ
KLZ is infamous around these parts
Lightbulb
I've a set of used H&R coilovers for sale posted on the "For Sale" forum, see if you will be interest
https://www.6speedonline.com/forums/...threadid=12329
orbelo
Aug 30, 2015 12:26 PM
Zero911
Aug 24, 2015 06:51 PM
TrackOne
Aug 20, 2015 12:56 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
