Need some help with Wheel Spacers
Old Apr 25, 2008 | 02:45 PM
jrustin's Avatar
jrustin is infamous around these parts
I am getting a set of 997 turbo wheels for my 2004 C4S, and am going to need 6mm spacers. I have spent most of the day trying to find some, with no success. Another question also is should I use a hub centric spacer, or can I get away with just a flat spacer, being they are only 6mm thick. If someone can point me as to where to get them, it would greatly be appreciated. Thanks.
Old Apr 25, 2008 | 03:34 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
I have not seen 6mm spacers.
H&R makes a 7mm spacer. Hub centric is always preferred.
http://www.automotion.com/productpag...cid=22&sid=321
Porsche has 5mm
http://e-partssales.com/Merchant2/me...Code=POTE996WH
Old Apr 25, 2008 | 03:36 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
we bought 7 mm spacers for both of our pcars from wheel dynamics. if you type in "wheel dyamics, porsche" you'll see accessories, etc. ask for carlos. he'll help you and let you know if they have other sizes
Old Apr 25, 2008 | 03:37 PM
racesx's Avatar
racesx is infamous around these parts
What's the difference between the two types as I'm looking to add spacers to my ride (probably 15mm)?
Old Apr 25, 2008 | 05:40 PM
jrustin's Avatar
Thanks for your responses. I will try the 7mm hub centric spacers. I guess 1mm won't make much of a difference.
Old Apr 25, 2008 | 05:49 PM
jrustin's Avatar
racesx, with 15mm spacers, you will have to use hub centric spacers. What it does, is center the wheel to the hub.
Old Apr 25, 2008 | 08:34 PM
Redridge's Avatar
7mm are to thin and cannot be made as hubcentric for our p-cars. Dont forget the longer bolts!
Old Apr 26, 2008 | 10:31 AM
racesx's Avatar
Thanks for the info. guys/gals!
Old May 1, 2008 | 04:34 PM
auto-xr's Avatar
auto-xr is infamous around these parts
Are there problems with the 7mm spacers since they can't be made hub centric? I thought I saw somewhere that they caused vibrations?
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
