Has anyone replaced their door sills?
Old May 30, 2008 | 09:23 AM
icemann633's Avatar
icemann633 is infamous around these parts
I have the carbon fiber version and like usual, it has faded.
I have replaced all of the CF but this piece but I think I want to now. Most of the sills that I see are the short ones.
Mine are the ones that wrap around the door jamb.
Has anyone taken these off? Is it tough? A lot of stickem left behind?
I think I want to go to the short aluminum version
-Keith
Old May 30, 2008 | 10:00 AM
daytrader's Avatar
daytrader is infamous around these parts
I replaced for a friend of mine. Not hard, just a lot of patience and good strong muscle. The best way is using a heat gun to soften the stickem. First, try to heat up the entire length of the sill. Then heat up the rear end of the sill, make sure don't leave the gun too close or too long. Use your own judgment. Turn off the gun, and use your fingers to pull up slowly. If adhesive still hard, heat it up again. Try again. Once the first few inches loosen you can have better holding power of the sill and the job is more easy. Stop when you can't pull up anymore. Again, heat gun is needed. Do this procedure until you lift the whole sill out. Use Gumout to quickly clean up the stickem.
It is much easier with two persons, and patience is the key. GL!
Old May 30, 2008 | 10:20 AM
icemann633's Avatar
Does the residue come off relatively easily in case i opt for the shorter sills instead of my long ones? Any discoloration?
If I am not worried about ruining my current ones, I technically couldn't overheat them right? Or is their secondary damage at risk?
Thanks!
Keith
Old May 30, 2008 | 10:33 AM
daytrader's Avatar
Ah, if you don't care ruining the current ones, then no need for slowly pull up the sill. Once you heat up the sill and get a good grip pull up hard, but still stop when you can't pull much further. Heat it up again to make job easy to work with.
The stickem material is almost the same as black silicon gum that you find at the Home Depot for sealing PVC pipe. No discoloring involved. The paint is in pristine when I cleaned up all the sticky gum, nice and smooth. Yes, you can damage the paint and the door weatherproof rubber seal if you have the gun too close and too long on one spot.
Warning! For secondary damage can be your fingers, your arms and your back. Hahaha!
Old May 30, 2008 | 10:34 AM
daytrader's Avatar
The sticky gum can be remove fast & EZ with Gumout. That is why I recommended.
Old May 30, 2008 | 11:09 AM
auclutch's Avatar
auclutch is infamous around these parts
i did it on my gt3 no probs. i'm sure that using a heat gun will be even easier.
Old May 30, 2008 | 12:44 PM
icemann633's Avatar
Thanks guys!
Now the decision to re-carbon or go aluminum!
Old May 30, 2008 | 12:51 PM
daytrader's Avatar
Originally Posted by icemann633
Thanks guys!
J9277655
Dec 28, 2015 11:01 PM
Michael_s
Sep 11, 2015 08:03 PM
LiquidElephant
Aug 27, 2015 06:17 PM
TrackOne
Aug 20, 2015 12:56 PM
