Emergency Help (Video w/Sound)
Old Jun 1, 2008 | 10:19 AM
MCM97's Avatar
MCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to behold
I was driving home last night and noticed a tick tick tick coming from the engine. I recently installed a K&N and thought the filter was hitting the pulleys. That's what it sounded like initially. However, after pulling in my garage it sounded a heck of a lot worse. Here's video with sound of the noise. Please turn your speakers up. I have a sinking feeling about this...
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://img.photobucket.com/player.sw...7/VID00001.flv">
The engine only has 69k miles on it. No fluids are leaking and no CEL's have been thrown. I don't know if that's a good thing or a bad thing.
Old Jun 1, 2008 | 10:27 AM
daytrader's Avatar
daytrader is infamous around these parts
Is this sound after you installed the K&N intake?
Old Jun 1, 2008 | 10:28 AM
Flyer007's Avatar
Flyer007 is infamous around these parts
MAN.......definatly mechanical and sure sounds like a rod.
As a DIY person.... the first thing I would do is drain the oil and check oil and filter for metal. With a sound like that I would send it to be sampled for bearing material.
You say it changed sound? Like it was something hitting a pully at first? So it was lighter then that? Then it got worst? How long did you drive it after hearing the inital sound?
Not good at all.....sorry.
MCM97's Avatar
yes, it's post K&N install but this has nothing to do with the K&N. Check out the video
Old Jun 1, 2008 | 10:30 AM
MCM97's Avatar
I noticed a tick about 5 miles from home but it sounded like the K&N hitting the pully which has happened before so I wasn't too concerned. It got very very loud when I pulled into the driveway
Old Jun 1, 2008 | 10:35 AM
racerjsz's Avatar
racerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to beholdracerjsz is a splendid one to behold
What year do you have?
Check your antifreeeze and oil. My old car made a sound like this before she let go.
Old Jun 1, 2008 | 10:36 AM
MCM97's Avatar
it's an 01.
I'm totally in a panic.
daytrader's Avatar
After hearing it, I think I know what it is. When I first installed the K&N intake I tested drive the car at WOT. Came back got the same similar sound that you have. I hope it is the same problem I had because it is a easy fix.
Have some one stand behind the car with engine lid open, look down closely at the back metal plate of the K&N against the engine pulley. You notice that there is a allen screw locate near the pulley on the K&N plate. What happened is that the designer of the K&N didn't see the screw location is too close to the pulley. Feel the allen screw for shaving. If the head screw was shave then you need to move the intake further out. There is not much room but it can be done.
Old Jun 1, 2008 | 10:49 AM
MCM97's Avatar
Exactly what I thought last night. I pulled the filter box out and it still exists. It very very much sounds like it's coming from the crank case. It's a very very consistant tick...if you increase the idle the noise increases in kind. It's very rhythemic...the wierd thing is that there's no tick tick tick tick TOCK sound like a rod got thrown.
Old Jun 1, 2008 | 11:24 AM
daytrader's Avatar
In that case, I would advise you to tow the car to a local indie. You don't want to risk the chance with major engine break down. Don't try to solve it when you are in the haze. GL!
Old Jun 1, 2008 | 07:39 PM
911C4S's Avatar
911C4S has a spectacular aura about911C4S has a spectacular aura about911C4S has a spectacular aura about
GL-with your fix! 6-speeders you guys/gals are awesome when someone is in the need of help! It's a support group for people with the same common interest--Pcars!!
Old Jun 1, 2008 | 07:46 PM
Redridge's Avatar
GL with this.... please keep us posted. TIA!
Old Jun 1, 2008 | 08:06 PM
MCM97's Avatar
Update - the engine isn't dropped but stuff is getting pulled apart. At higher revs (when the pressure in the cyl is higher) the noise isn't as bad. I feel with a 90% chance that it's a collapsed lifter. Should have the valve cover off tomorrow and thus a high % diagnosis.
Thoughts with the new info? I can live with a lifter issue - the thought of a rod being in 3 pieces really makes pucker
Assuming this is a collapsed lifter is this a common/known problem?
Old Jun 2, 2008 | 09:12 AM
Flyer007's Avatar
Your really getting into the area of renntech.org now Loran and or toolpants there should be a great help. I have not looked there to see if you have posted.
Old Jun 2, 2008 | 09:14 AM
lucky_topher's Avatar
lucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant future
yeah, i posted for him at renntech... not much response yet
