Need Help!!! tires rubbing!
Old Aug 12, 2008 | 09:03 PM
vf_1s's Avatar
vf_1s is infamous around these parts
Hi, I have a 03 996 C4S, and I bought a set of HRE 841r from a 996 turbo, which i was told to have the same off set and no problem.
I put the wheels on and the rear tires stick out so much that it rub and the fender cut into the side wall of the tires. What went wrong?
I read in the general manual for 996 that there are spacers, does this apply to the C4S as well? if so how do I remove it?
I have attached some pics, not sure if the grey part is the spacer, I tried taking it off, but is seems to be connected to the brake disk.
Thank you in advance.
Old Aug 12, 2008 | 09:14 PM
JayFunk's Avatar
JayFunk is a jewel in the roughJayFunk is a jewel in the roughJayFunk is a jewel in the rough
hey there.....
technical, yea wheels from a turbo 996 SHOULD fit a C4S since its the same type wide body. as for why they stick out a little more than it should confuses me. the wheels on your car do sit a little more flush than it should. whats the tire sizes on the wheels now? also, there is no washer on the hubs so that isnt a concern at all. do the fronts rub also? give us some more info to help ya out.
jay
Old Aug 12, 2008 | 10:06 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Don't take this the wrong way, but are you positive you were sold a widebody?
Old Aug 12, 2008 | 10:47 PM
vf_1s's Avatar
thanks.
1.) i am sure mine is a c4s wide body
2.) no, the front doesn't rub
3.) my tires are pilot sport II, and sizes are:
235-35-19 front
315-25-19 rear.
It is the rear that rub, but in comparison, they are the same width as the original c4s tires.
what about the grey part on the hub?
it is only held on by 2 screws? just that it seems to be connected to the brake disk in the back. do you think that is the spacer?
Old Aug 12, 2008 | 11:05 PM
Malakas's Avatar
Malakas is infamous around these parts
I certainly don't have an intelligent answer beyond the offset's being off. On pic 3 - measure the distance from the center to the floor - make sure they are the same. My dad ran 315s on his 997 C4S on 19s so width is not the issue... [noted below: oops ]
On the plus side - the wheels will look sick.
Old Aug 12, 2008 | 11:13 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Did you ever see pics of them on the Turbo? Some people buy their wheels that way. They may have had a very aggressive offset. You dont have spacers..thats you hub...dont remove that. Whats the width of the rim and offset? That will tell you if there is a problem. Also is your car lowered? Have you had the camber adjusted on the rear of your car? It could be that IF the Turbo was lowered and had an aggressive camber that the tires would not have rubbed on that car, while your car ha a more conservative suspension setup and thus it rubs.....
Oh Malaksa...a 997 C4S is wider than a 996 C4S so you cannot compare the 2.
Old Aug 12, 2008 | 11:15 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
nevermind.... posted same time as newport........
Old Aug 12, 2008 | 11:32 PM
The Dark Knight's Avatar
The Dark Knight is infamous around these parts
Here's a pic of them on a Turbo and they are more recessed
Call these guys since they sell them and ask for assistance
http://wheelsperformancecom.stores.y...11tuhre84.html
The offsets are obviously dramatically different than the original turbo twist rims based on your pictures. Here is an offset calculator for you as well. The offsets should be listed on the back of the rims.
http://www.1010tires.com/tech.asp?type=wheels#offset
HC
Old Aug 12, 2008 | 11:49 PM
Ask Vivid Racing as well. The run as wides as 13"
http://www.vividracing.com/catalog/h...4825_4834.html
HC
Old Aug 12, 2008 | 11:50 PM
They run as wide as 13"
Old Aug 13, 2008 | 01:06 AM
scwerks's Avatar
scwerks is infamous around these parts
first thing you must do is find out the offset/backspacing of those wheels then we can determine if it should or should not work on your c4s. it's clearly an offset/backspacing issue here. the screws that you circled is what holds the hub/rotor. DO NOT take that off unless you're swapping rotors.
some scenarios:
- the previous owner lied about the wheels being on a turbo 966
- his rear suspension had some serious negative camber
- his car wasn't as low as yours therefore he probably never ran into this problem(still an offset issue)
- if the tires you have on now aren't the ones that came with the wheels, he probably used narrower tires giving it that stretch euro style look.
- he had his rear fenders rolled
- something is wrong with your rear suspension, any previously known accidents??? does the other side rub too???
i could be completely way off with everything i just said.
Old Aug 13, 2008 | 07:34 AM
HREMarc's Avatar
HREMarc is infamous around these parts
Call John at HRE @ 760-597-2001
Give him the serial number off of the back
It will be: R_____ or F_____ with 5 numbers after the F or R
He will tell you whats up.
Marc
Old Aug 13, 2008 | 08:05 AM
vf_1s's Avatar
Thanks everyone, I will try to get in touch with John and find out what happen.
Old Aug 14, 2008 | 08:15 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
very easy fix
i had the same problems with my 4S and TechArt wheels
get your fenders rolled. costs like 300-500 depending on where you get it done
Old Aug 14, 2008 | 08:19 AM
angldrkns9's Avatar
the same wheels will rub on a turbo and not a 4S because of the suspension settings, depending on how your suspension is setup and how it's dialed in, the wheel will be angled/positione differently
just get your fenders rolled
