uh oh......
Old Dec 15, 2008 | 04:47 PM
pjalexandre's Avatar
pjalexandre is infamous around these parts
Berk,
Gimme a call tomorrow. Just read this now.
-Paul
Old Dec 15, 2008 | 04:51 PM
racesx's Avatar
racesx is infamous around these parts
Here's my run down two months ago for parts from Sunset.
Clutch kit $457
Flywheel $790
Someone mentioned the other day that Suncoast has it all for a lot less these days??? Might be worth a call, and depending on location, maybe cheaper on shipping.
GL!
Old Dec 17, 2008 | 06:09 AM
boochook's Avatar
boochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond repute
Hey Sharp, that does not seem to be the case thankfully.....the RPM's flow consistent through the band in third and all the other gears for the most part.
Originally Posted by Sharp
are your RPM's spiking when you try to accelerate? of course without proportionate acceleration? cause thats a good indicator that your clutch is shot.
Old Dec 17, 2008 | 06:10 AM
boochook's Avatar
DJ - I'm thinking that might be the next step, RMS I haven't checked yet, but will do.....thanks for the direction.....
Originally Posted by djhill
Maybe consider a light weight clutch. Be sure to check the RMS.
Old Dec 17, 2008 | 06:15 AM
boochook's Avatar
Hey Joey, I have just under 39K miles on the car. Like you said, it has slowly started to get better again, like regenerating itself..........man, I LOVE MY P-CAR, these things are robust!!!!
Originally Posted by JoeyM
you dont say how many miles you have on your clutch.
if you dont have many miles on it, i would wait it out some. you may have just glazed the clutch.
you may still have a lot of life left in the clutch. drive it around some more. it may get better on its own.
Old Dec 17, 2008 | 06:21 AM
boochook's Avatar
Racesx - Thanks for the direction my friend, I've heard nothing but great things about Suncoast, so I'm definitely going to give them a call once I figure out what needs to be done....
Paul - Thanks for the call yesterday dude, I appreciate you helping with the diagnostics man.....
Berk
Old Dec 18, 2008 | 10:48 AM
JoeyM's Avatar
JoeyM is infamous around these parts
good to hear. yeah wuith 39k you prolly have a decent amount of time left.
me and my friends have autox'ed awd cars for awhile. we have had a fair share of f*cked up hard launches that resulted in no car movement and just smoke.
i can remember a particularly bad one that happened in my awd audi early on when it had less than 20k miles on it. it was a day of at least a dozen hard autox launches. then later that day, same deal on the street going home, almost getting hit accelerating hard and the clutch slips and smokes up. horrible smell and all that.
well, it was not so great for a few days of driving after that (would slip occasionally). but that soon went away and the clutch and flywheel lasted til 80k. considering how much it was thoroughly abused we were very amazed.
Old Dec 18, 2008 | 11:13 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
that sucks. i did that once and i thought i broke my clutch. good luck with the fix. suncoast will take good care of you.
you should def put in the most updated RMS seal while you're at it. i think it only costs < $50 from suncoast.
Old Dec 19, 2008 | 11:14 AM
boochook's Avatar
Jason - definitely will....and the RMS piece also. Is that something I should just do right now???? Even if the clutch seems to be fine????
I sent a PM to Steve @ Suncoast a few days ago, but he has not replied back yet?
Old Dec 19, 2008 | 11:46 AM
angldrkns9's Avatar
the people are suncoast are pretty busy, it's sometimes hard to even get them on the phone
i would only do the RMS if it's leaking pretty bad (oil spots on the floor) since i've heard that even the updated seals leak a bit
mine is leaking on the floor
boochook, if you want an RMS seal that doesn't leak, do some research into the racing/track RMS seals. Paul at Protomotive is installing that seal for me and he's never had it leak. he even warranties it for 2 years
if you're clutch is fine, i would save your money, no need to repair something that isn't broken
Old Dec 21, 2008 | 10:38 AM
boochook's Avatar
^^^dually noted......I LIKE YOUR THOUGHT PROCESS.....If it ain't broke, don't fix it.......
Old Dec 22, 2008 | 06:20 AM
SuncoastSteve's Avatar
SuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to behold
Hey Berk! I haven't forgotten about you, just need to have a couple phone calls returned on one of the parts you requested (it can sometimes be a bit tough to find an aftermarket piece through one of the vendors we work with). Let me know when you're available to chat today, or shoot me a phone call!
Old Dec 23, 2008 | 11:07 AM
boochook's Avatar
Hey Steve, No worries, I'll definitely drop you a line. I can imagine you guys must be really busy this season......I'll hit you up soon. Thanks again.
Berk
KaamaCat
Jul 30, 2010 11:25 AM
