Wiring Options - Front and Rear to Cab
Old Mar 6, 2009 | 11:05 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
Hi there,
If anyone has directions with pictures of how to get wiring from the front and rear bumper area to the inner cab, please let me know.
I want a clean way to do it with the least amount of disassembly and next to no drilling if possible.
Cheers
Aaron
Old Mar 6, 2009 | 11:15 PM
Jam996's Avatar
Jam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud of
rear : there is a rubber grommet behind the rear seats under the carper. cut little splice and it takes you to the engine cabin.
front : remove carpet in trunk, remove plastic cover next to battery on driver side, remove plastic cover over brake oil reservoir, route your wire behind carpet thru the rubber grommets to the interior cabin.
no drilling involved. sorry no pics.
pm me if you need more info.
Old Mar 7, 2009 | 06:17 AM
deckman's Avatar
Please document your work if you have time, to include pics. I will be doing something similar this spring. Good luck!
Old Mar 7, 2009 | 02:00 PM
Purplxd's Avatar
Will do, I remember you were looking for a laser jammer install info...
Cheers
Aaron
Old Mar 8, 2009 | 02:55 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
Same here...
Old Mar 8, 2009 | 10:02 PM
Redridge's Avatar
search for installing PSE on rentech.... there are 2 grommets (left and right side) located at the very rear deck, under the carpet....
Not sure about the front, but if you follow the cabling for the CD box in the trunk... it should get you there.
Old Mar 9, 2009 | 12:44 AM
Purplxd's Avatar
Will be doing it this week so will be sure to take all pictures.
Cheers
Aaron
Old Mar 11, 2009 | 08:23 AM
spmorgan's Avatar
spmorgan is a jewel in the roughspmorgan is a jewel in the roughspmorgan is a jewel in the rough
The front is easy. I just did some stereo wiring through the bonnet into the cabin...once you remove all the carpet/plastic covers in the front, you will see the grommet from the bonnet to the battery area, and then if you pull the battery out, you will find a rubber grommet that is to the left of the battery that you can run into the cabin. You can then grab the wires from within the drivers side footwell.
Old Jan 29, 2011 | 09:12 AM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
re: the front - what this man said - about a dime sized grommet- got a hanger+ 2 wires through no prob, comes out the other end above the pedals.
easy.
will post a pic soon.
Old Jan 29, 2011 | 09:25 AM
fourempties's Avatar
fourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond repute
Front to cab is easy. Getting from under the accel pedal to the rear is the hard part. This write is really good:
http://dougturner.com/porsche/sound_system_2009/
Old Jan 29, 2011 | 07:38 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I installed front LI's. Ran the wire under the rubber trim that seals the front hood to the front boot. Then there was a rubber grommet behind the battery and just in front of the driver. Then I used a rear defroster switch and one these to control the switch. Works great.
Old Jan 30, 2011 | 03:03 PM
Purplxd's Avatar
Wow talk about resurrection of a dead thread.. I did this install ages ago.
Cheers
Aaron
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
gulf gt
Aug 27, 2015 10:27 AM
