Help. Key stuck in ignition
Old Sep 15, 2003 | 07:18 PM
C.Plavan's Avatar
C.Plavan is infamous around these parts
Anyone ever have their key get stuck and not want to come out of the ingnition? it turns and starts the car but will not release. Mine does not wanna come out no matter what I try.... Hmmmm this sucks. The car is not leaving my garage with the key stuck
Old Sep 15, 2003 | 07:49 PM
Mon's Avatar
Mon
Mon is infamous around these parts
try to move the steering wheel and twist the key
Old Sep 15, 2003 | 08:01 PM
C.Plavan's Avatar
I tried that before. I could of sawed logs moving that wheel back and forth to release the key. Still would not release
Old Sep 15, 2003 | 09:06 PM
Kevin M's Avatar
Modaholic
Kevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond repute
did you try KY yet? sorry I had to ask...
Old Sep 15, 2003 | 09:38 PM
Shawn C's Avatar
Shawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond repute
Common Problem
I had my ignition swapped out twice for the same reason.
Take it to the dealer its covered by your warranty.
Old Sep 16, 2003 | 12:14 AM
Tool Pants's Avatar
Tool Pants is infamous around these parts
One of the signs of a bad ignition switch. Jeff
Old Sep 16, 2003 | 09:30 AM
tsweat's Avatar
tsweat is infamous around these parts
Ignition Switch
Same experience/thoughts as the folks above. I actually had mine replaced last week, unfortuntately it was not covered by warranty since I have a 99' year model. Parts & Labor ran around $150. They fixed it while I waited; total time was just a bit more than an hour. I scheduled it at lunch time, so it worked perfect.
Good Luck...
Old Sep 16, 2003 | 10:07 AM
tsweat's Avatar
Forgot to mention...
Also, if you are having trouble with your A/C because of the ignition switch issue, try this:
Once the car has been started and if the A/C is not working, turn the key a small amount back to the left, not so far as to kill the engine, but just before that point. This should kick the A/C back on and will help keep you cool while going to the dealer...
Good Luck
Old Sep 16, 2003 | 11:06 AM
Tool Pants's Avatar
Chad, we work on cars again this weekend in San Jose and will be filming more video. Aileen 'Madam No Fear' will be there to take apart a GT2.
Buy new switch. Drive straight from your garage to San Jose. Put new switch in. Drink beer. Jeff
Old Sep 17, 2003 | 08:48 PM
C.Plavan's Avatar
I may do that. The only problem is that I'm on a business trip in Houston. I'm hunting down Enron managers...j/k...I also could not get the switch in time . Thanks for the offer though.
Old Sep 21, 2003 | 10:10 AM
C.Plavan's Avatar
I got it fixed. Thanks for the info guys. Loren and Jeff thanks for the detailed instructions. I had to make my own little "Special tool" to get the little screws out. I actually cross referenced a VW ignition switch and picked one up locally (Yes there are still VW parts in our Carrera's) It was not that hard when you have a cut off wheel and an old little screw driver need to make a tool . The key releases now without a problem and everything works!
Thanks guys
lokmeup
Sep 9, 2015 09:24 PM
Yogi911
Sep 9, 2015 08:20 PM
albert@velosdesignwerks
American Muscle Vendor Classifieds
Sep 9, 2015 04:21 PM
Suds26
Sep 2, 2015 01:33 PM
