Remote Key Fob Programming & Laser Cutting for 996
Old Jun 11, 2021 | 07:27 AM
DonovanMitchell's Avatar
DonovanMitchell is infamous around these parts
I have called locksmith astoria near me and they programmed the remote fob in just two hours.
Old Jun 14, 2021 | 04:22 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
New key fob is approx $160-180 from dealerships via eBay. Then you need a blank key that gets cut. Then PIWIS uses the 24 digit unique code on the key fob to pair with the immobilizer once you have the IPAS codes. (key start + remote locking)
If you go through a locksmith you likely won't be able to remote lock/unlock the doors. You will get a key clone that can be used to drive the car. You can manually unlock the doors but if you don't key on the ignition fast enough the alarm will start hoking at you.
charha01
Feb 7, 2017 02:26 PM
kennyPride
Jun 29, 2016 04:01 PM
tphss
Feb 11, 2011 10:18 PM
GreyPepper
Cayenne 955/957
Sep 18, 2009 01:52 AM
tsmithmdtx
Oct 5, 2007 02:14 PM
