will wide body wheels fit a narrow body car?
Old Dec 20, 2009 | 05:22 PM
Omarcoolguy's Avatar
Omarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant future
will 19x11 rear fit NB 996?...whats the differnce if theyre made for a widebody, is the offset different or is it just wider?
Old Dec 20, 2009 | 06:11 PM
nijoma's Avatar
nijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud of
Depends on the offset
I have 11 inch rears but the offset is made for a NB.
Old Dec 21, 2009 | 12:00 PM
PierceZ's Avatar
PierceZ is infamous around these parts
I have the 19x11 rears with the wide body offset. They don't rub, but they do stick out just a little, which I'm fine with. Most likely next summer I'll roll the fenders which will solve that problem.
They also seemed to stick out less after I lowered the car
Old Dec 21, 2009 | 05:12 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Rolling the fenders won't change the way the wheels stick out, it only pushes the metal lip up some on the inside. I know because I rolled mine. To know whether the widebody wheels will fit you need to know the offset of the wheels, and the size of the tires you will be using. I have a set of widebody wheels, only 10" wide, I forget the exact offset, and when I put them on with 265/40-18 PS2 (as opposed to the standard 265/35-18 tires) they rubbed. Rolled the fenders, and they still rubbed. With 275/30-18 probably would have worked.
Look at 1010tires.com for an offset calculator that will show you how much difference in wheel sizes makes. However, this still does not account for tires sizes. The safest bet is to go with wheels designed for the NB.
Old Dec 21, 2009 | 05:26 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
^^^ what Dharn55 said.
Plenty of options for 11" wide rears in NB fitment are out there, no need to risk it on WB wheels.
Old Dec 22, 2009 | 12:43 AM
whats the offsets ? nb ~wb
Old Dec 22, 2009 | 02:40 AM
SealGrey986's Avatar
SealGrey986 is infamous around these parts
I`ve narrow body (-00) C2 with rolled fenders and have run next wheels & tires:
11x18 (nb et, don`t remember exactly) with 295 Pirelli Corsa Motorsport
11x18 (nb et56) Michelin PS Cup 295 & Toyo R888 295
10.5x18 (widebody et 42? for 996 turbo) with 295 Conti Sportcontact2
No rubbing on any of these combinations even with lowered suspension. Can`t remember how much but a bit lower than euro gt3. I think you need to have rolled fenders to run widebody rear wheels
Old Dec 22, 2009 | 06:29 AM
mhemperly's Avatar
mhemperly is infamous around these parts
i ran 19x11 with 305/25/19 dunlops on my old NB and with rolled fenders and i was slammed, NO RUBBING!
Old Dec 22, 2009 | 06:41 AM
happymcwn's Avatar
happymcwn is infamous around these parts
nice body i have seen above....
Old Dec 22, 2009 | 07:03 AM
Dharn55's Avatar
For a 2000 NB with 18" wheels, 8" on front and 10" on rear the offsets were 50 front and 65 rear.
Old Dec 22, 2009 | 07:36 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
19x11 et 67 (from a WB 997) with 305/30/19 no rubbing.
gulf gt
Aug 27, 2015 10:27 AM
pwdrhound
Aug 20, 2015 05:54 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
