Door speaker upgrade
Old Mar 21, 2010 | 01:37 AM
Sharky996's Avatar
Sharky996 is infamous around these parts
What's the largest component speaker you can install in the 996 door without major modifications/cutting? 7"? 8"?
6.5" - no cutting?
7" - some trimming?
8" - major cutting?
Old Mar 21, 2010 | 05:09 AM
nijoma's Avatar
nijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud of
I have alpine in the door and dash and rear seat
I have a 996 cabrio, I am trying to upgrade larger than stock also. I picked up a set of large bose speakers out of a turbo 996 to see if they fit but I think I will have to cut, which I do not want to do. The six alpine's sound good in the stock size and there are much better speakers than alpine out there, might be worth looking before cutting.
Old Mar 22, 2010 | 01:16 AM
Sharky996's Avatar
I'm probably not going with the stock 5" size, no matter how good the replacement speakers may be.
Has anyone installed 6.5", 7" or 8" speakers in the doors, and how much modification was necessary?
I would imaging that you will need to ditch the stock enclosures for sure.
Thanks!
Old Mar 22, 2010 | 08:51 AM
jrsheltra's Avatar
jrsheltra is infamous around these parts
You will have to ditch the enclosure if you go bigger, 6.5" shouldn't be an issue. I don't really see a reason to go larger than a 6.5 in that car I will say without the enclosure you need to build a plate that will seal to the door so the back waves from the speaker do not meet the front killing your midbass.
Old Mar 22, 2010 | 09:28 AM
Sharky996's Avatar
Sounds like good advice. Maybe a combination of MDF and Dynamat?
Old Mar 23, 2010 | 11:20 PM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
5" focal subs fit in the doors with almost no effort....anything larger requires cutting and most likely fiberglass work
Old Apr 20, 2010 | 06:23 PM
boogie996's Avatar
boogie996 is infamous around these parts
asialors996, i've read some of your posts and it seems you've managed to do what i want to do! how did you get the 5.25's in the rear utilizing the original speaker grille? what did you do? can you supply me with the details? thanks
Old Apr 20, 2010 | 08:27 PM
JomamaGT's Avatar
JomamaGT is infamous around these parts
I have been able to install a 6.5 in the pod with quite a bit of cutting. I could not fully press the interior door panel on the plastic fasteners because of the size. If I dremeled the grills it might allow full contact. I currently have Alpine F1 Status 5.5s which allow a flush fit. If you go larger, I think you will need to ditch the pods and go with a custom box.
Old Apr 20, 2010 | 11:01 PM
there are adapters available out there for the rear speaker location....
Old Apr 22, 2010 | 03:54 PM
boogie996's Avatar
I'm hoping to keep things as original looking as possible.. not necessary but i want a clean look and plenty of punch.. the larger the speakers the better. it seems 4 inch in the front and at best 5.25 in the rear and doors. anything more is going to cause problems.. like JomamaGT says a box may be the only cure.
Old Apr 3, 2011 | 05:20 PM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
interestin with no answer yet
Old Apr 3, 2011 | 05:25 PM
What answer are you looking for
Old Apr 3, 2011 | 05:44 PM
gu9cci's Avatar
fitting 6 1/2 inch woofers in existing enclosures...pictures/modification?
Old Apr 3, 2011 | 08:11 PM
aemr1968's Avatar
aemr1968 is infamous around these parts
It not about size... It's about quality... You need to buy Focals for best sound possible... 4" Focal sound much better than 6X9 Alpines... Now, if you just want loud noise I agree go with bigger speakers and a big amp
Old Apr 3, 2011 | 08:13 PM
gu9cci's Avatar
why focals?I personally don't like focals because they too bright.
