No brake lights! Help!
Old Mar 25, 2010 | 07:02 PM
DaveFL1976's Avatar
DaveFL1976 is infamous around these parts
Hey folks, I noticed tonight that the brake lights on my '99 996 are not working. All other indicator lights, blinkers, hazards, etc are working fine.
But no brake lights. Not even the 3rd brake light or the one attached to the spoiler that's supposed to come on when it's raised. The only thing I checked tonight was the fuse (B7 according to my fuse diagram) and the fuse was intact. Didn't break out the volt meter yet, though. I've got tomorrow off so I'm going to do some investigating in the morning.
Does anyone have any pointers for me getting this repaired?
thanks!
Old Mar 25, 2010 | 07:08 PM
cviper1's Avatar
cviper1 is infamous around these parts
Check your brake pedal position switch.
Old Mar 27, 2010 | 12:00 PM
DaveFL1976's Avatar
So I verified that there was power going through the fuse, and I pulled out a light bulb just to make sure that it wasn't a simple fix.
Ended up taking it to the dealer yesterday, and indeed it's the brake petal position switch. The tech said it's an uncommon failure but it does happen (he said they replace about 10 per year if he had to guess). Part should be in on Monday. $158 installed.
Old Mar 27, 2010 | 01:58 PM
cviper1's Avatar
Well atleast it wasnt something like a wireing problem. I work as a tech for ford and I see about 15-20 of these a year. Glad your got it taken care of.
Old Mar 28, 2010 | 08:03 PM
Justahonda's Avatar
Justahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud of
I just did one of those last week! It is quite an uncommon issue though
J9277655
Dec 28, 2015 11:01 PM
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
