Need Help Strange Happening
Old Jun 6, 2010 | 10:16 PM
911C4S's Avatar
911C4S has a spectacular aura about911C4S has a spectacular aura about911C4S has a spectacular aura about
Problem: When making a sharp or semi sharp turn (Ie. Fwy off ramp) my car feels like it's down shifting, but I'm not. Only happens when I make these turns, but it concerns me greatly. Driving straight it's fine. I did recently get 2 new tires for the rear though. Not sure if that matters. I do need an alignment which is going to happen this week. Any help would be appreciated before I take my ride in. Thanks again..
996 C4S
2003
31K miles
Coupe
Old Jun 7, 2010 | 02:53 PM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
Not enough info to be of much help.
6spd manual or auto?
If manual, could it be the clutch slipping?
Old Jun 7, 2010 | 08:09 PM
Chickenplucker's Avatar
Chickenplucker is infamous around these parts
Any chance you are braking with your left foot while applying throttle? If so the engine will cut power and can feel like it's downshifting. Just a thought...
Old Jun 7, 2010 | 09:51 PM
911C4S's Avatar
Manual shift
31K miles,
Never tracked or abused
Original Clutch
*Drive perfect around town---I'll check for impediments below brake pedal.
Off the subject what do you guys run your tire pressure fronts: Rears: Thanks
Old Jun 9, 2010 | 10:36 PM
Airrik's Avatar
Airrik is infamous around these partsAirrik is infamous around these parts
36 to 37 psi fronts; rears 40 to 42 psi. This is when avg. temps around 80 to 90 degrees. Hope this helps
Old Jun 9, 2010 | 10:41 PM
rh888888's Avatar
rh888888 is infamous around these partsrh888888 is infamous around these parts
Exactly the same thing happen to mine it is the new rear tires. As soon as I put a few 100 miles on them it stopped. The dealer told me it was common when replacing rear tires only. Don't sweat it but be carefull for a little while.
Old Jun 10, 2010 | 11:08 AM
911C4S's Avatar
Car is back to normal. The rear tire(s) pressure was set to high. Made the car handle terrible and set off the traction system.(My conclusion) Thanks for all the help..
Old Jun 10, 2010 | 12:25 PM
davebho's Avatar
davebho is infamous around these parts
so what were they at?
So what were they originally set at to cause the issue, and what did you set them to in order to get around the issue?
i'm slappin in new tires and will just use factory recommended settings and want to know in case i have this issue.
Thanks, dave
Old Jun 12, 2010 | 10:44 PM
911C4S's Avatar
Tire pressure
Thanks, dave
Dave,
The factory manual said 45 Cold PSI which for my C4S appears to be too much....Car felt unstable and didn't handle well. Ended up lowering the psi to 35 in the rear..The fronts are set for 30. Everything now is working fine. Never thought the traction control system was so touchy. I might have to go lower cause today I took an off ramp kind of fast and I did feel the problem again, but very faint. Hope that helps..
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
jab23
Cayenne 958
Oct 2, 2015 08:40 AM
Mz3bo
Oct 1, 2015 06:32 PM
nagual911
Oct 1, 2015 01:52 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
