need help now!
Old Aug 22, 2010 | 02:32 PM
crazyed71's Avatar
crazyed71 is infamous around these parts
need help now!
OK,
Swapping out some by-passes, i was following the DIY and lifted the car from the motor... I almost had the right side muffler out so i lifted a bit more, maybe a total of 6 ".. On the passenger side, the engine mount begun to poor black fluid... in pics... so i finished the job, removed the lift and used the driver side jack position to remove other muffler... Once i had removed the jack from under engine no leak what so ever (even while i had lifted the driver rear tire).. what can it be, is it safe to drive?
Old Aug 22, 2010 | 02:37 PM
crazyed71's Avatar
BTW,
2000 c4, lowerd never had a single drop anyware
Old Aug 22, 2010 | 02:40 PM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
Sounds like you ruptured a motor mount and it will have to be replaced.
Why not use the jack points on the rear side?
Old Aug 22, 2010 | 02:41 PM
crazyed71's Avatar
I read you could lift from rear.... Can i drive the car?
Old Aug 22, 2010 | 03:22 PM
Brando's Avatar
You can....but if your motor mounts are old, this is what can happen.
I'd drive it easy to the repair shop.
Old Aug 22, 2010 | 04:20 PM
farfinator's Avatar
farfinator is infamous around these parts
Yup, sounds like a blown engine mount.
Yes you can drive.
Should replace as soon a convenient.
1. Can get used from DC auto.
2. Can try solid: http://www.wevo.com/Products/Chassis...gineMounts.htm
3. Can use 964 RS Mounts:
(2) 964-375-043-81 Mounts
(4) 901-305-311-00 Wahsers
(4) 999-025-074-01 Washers
(2) 12x1.5x125 Bolts
Old Aug 22, 2010 | 08:37 PM
crazyed71's Avatar
well,
spoke to mechanic, definetly motor mount... i found a set for 140$ Both... he will charge 1 hour labor... worse thing about it, as soon as i heard the car with muffler by-pass, i got back under and got the OEM back on....
2 hours and a mount later..
ALL FOR NOTHING!
Old Aug 23, 2010 | 06:53 AM
Redridge's Avatar
well,
ALL FOR NOTHING!
not all for nothing.... you are wiser now.
Old Aug 23, 2010 | 07:09 AM
crazyed71's Avatar
"Wiser"
Damm straight!
