How do I raise my stock rear suspension an inch?
I recently bought a '99 996 and I'm loving it! The only problem is that the last owner put wheels with spacers on that are a size too big. When I hit bumps the tires bottom out on the edges of the wheel wells. I want to keep the tire/wheel package so I want to raise the rear suspension by about an inch (maybe less). I'm trying to figure out the easiest/cheapest way for my mechanic to do it. I know I could replace springs but I don't want to if I don't have to. He has mentioned using shims and placing them at the bottom of the springs. Sounds good to me but we can't find them anywhere. I'm sure I could get them machined if I knew anyone but I don't.
If anyone knows where to get these shims or even a proper name to google search I'd be very appreciative. Also, if this sounds like a terrible idea and there is a better way, please let me know. Finally, if I change the ride height, will this effect the camber? -Mike
You don't want to "shim" the suspension of your porsche, it doesn't work like a pickup truck with leaf springs and of course it will throw your alignment out of whack. Are you running stock or aftermarket suspension now?
Do not run two different suspension systems on your car. If your shop is telling you this is the cheapest way.. find a new shop.
Cheaper ways?
Take the spacers out or put smaller ones in
Roll your fenders
The same cost-
Get a proper wheel setup and re-use the rubber
Cheaper ways?
Roll your fenders
The same cost-
I suppose that I could do that. I kind of like the current width but I'm sure I'd barely notice the difference. I don't know the current spacer size but I'll check. What's a good spacer supplier? Thanks
I think H&R has a few sizes. I know that they have them in performance automotive- porsche.. even ebay would work, they dont have a lot of pressure on a 7mm spacer and any aluminum one should work fine.
You will notice the spacer much less than than a suspension lift. An inch is HUGE on these cars.
If they are only rubbing slightly you can roll the fenders. I did this to mine. Rented a tool from this company:
http://www.rollyourfender.com/
I did it 4+ years ago before they had the adapter for the Porsche wheel hub so I had to improvise. If you Google "roll your fenders" you will find lots of info, some people do it with a baseball bat, I think the tool is a better way to go.
Thanks to everyone for the tips. I think I'm going to roll the fenders. Seems like the best solution. I just need to check for clearance against the inside edge of the fender. I know it's close. Thanks again.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
