Best Spark plugs? coil packs?
Old Nov 23, 2010 | 03:28 PM
sempaipaul's Avatar
sempaipaul is infamous around these parts
title says it all... Looking for best ones out there, and ofcourse the most bang for the buck.
Also do I need anything else besides the plugs and the coils to do that service?
thanks,
Paul
Old Nov 23, 2010 | 03:57 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
thanks,
Paul
I have always liked Bosch, my car is a 2000 w/ 89,000 miles & original coils, why do you want to replace the coils?
Old Nov 23, 2010 | 05:43 PM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Arrow Sorry, but...
...have to respectfully disagree w/Bosch as the way to go.
Quality and durability of Bosch over the years has gone down the tubes.
IMHO, Beru plugs and coilpacks would be a much better choice.
Old Nov 24, 2010 | 04:53 AM
juanchi300's Avatar
juanchi300 is infamous around these parts
Try iridium, more expensive, but last
Old Nov 24, 2010 | 06:37 AM
sempaipaul's Avatar
ok i see,
Hm, I am wanting to replace the coil packs because its misfiring, but I guess maybe i should first replace the spark plugs, and then replace the MAF as I think the misfire might be caused by that and my K&N intake...
Now when we pull the coilpacks on our cars, you pull off the coil pack, and does the coilpack connect right onto the spark plug? or is there any rubber boots? spark plug connectors? can someone post a link to those..
Thanks,
Paul
Old Nov 24, 2010 | 06:47 AM
juanchi300's Avatar
yes, the coils connect direct to the sparks plugs
Old Nov 24, 2010 | 07:00 AM
Zookie's Avatar
Factory... try Suncoast for Best Price!
Old Nov 24, 2010 | 09:24 AM
jeneric996's Avatar
jeneric996 is infamous around these parts
I think your 2000 996 has oil tubes between the coil and spark plug. You need to pull them out after you remove the coil. I have read some used a boat plug with a T at the end of the plug to insert and remove the tube.
If your MAF is a problem, you should also have a check engine light with a rough idle.
You may want to change the spark plugs and check to see if any of the coils are cracked. If so, then replace the coils too.
I purchased my spark plugs at Sunset Porsche in Oregon. They are factory plugs made by Bosch. My original ones in my 2003 were Beru. Sunset's price was slightly less than Suncoast at that time.
Old Nov 24, 2010 | 09:34 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
If you are going to replace the spark plugs, do all 3 stuff. The plugs, the plug tubes and the coil packs. Same exact labor so do it right once. Price is around plugs - ngk for 50. Oem tubes - 30. Beru coilpacks -250. I had them done all separately so had to remove the mufflers 3 times. Not fun.
Old Nov 24, 2010 | 09:40 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
how are the NGK spark plugs? I just bought some and they only cost me $30 if i recall correctly. I was planning to use those with new beru coil packs.
Old Nov 24, 2010 | 09:51 AM
geetee's Avatar
I currently have NGK BKR6EK waiting to be installed so no review on these.
I have been using another NGK with the single plug...can't recall the part number without any problems.
I think it was the BKR6E's
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
jaehoppa
Oct 22, 2015 09:17 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
jungt
Sep 16, 2015 05:28 AM
