Need help connecting iPod in place of CDC-3 cd changer
Old Jan 14, 2011 | 07:15 AM
tcleaver's Avatar
tcleaver is infamous around these parts
The CD changer is connected via the stock cable to a CDR-220. The cable terminates in a pair of female RCA connectors and a round DIN plug. I disconnected the CDC-3 and then hooked up an iPod to the RCA connectors using an Apple dock connector to RCA cable. I did not leave the DIN plug connected. On the CR-220 I got AUX in place of CDC but there was no audio whatsoever (not even at full volume). I reconnected the DIN connector and the CR-220 showed CDC in place of AUX but I still got no sound. Am I missing something here or will the Becker head units not recognize anything other than their CD changers connected to the RCA plugs?
I am getting a CDR-220 next week, so that I can still have access to a CD player once the CD changer is removed. Becker sell a cable that runs from the back of the head unit to an Apple dock connector connection and the Becker head unit will then recognize the iPod on the AUX source. If hooking the iPod to the CD Changer RCA connectors can't work then I'll order the cable from Becker.
Suggestions?
Old Mar 29, 2011 | 09:26 PM
Mullypro's Avatar
Mullypro is infamous around these parts
bump in it hoping for an answer
Old Mar 30, 2011 | 09:28 AM
02C4S's Avatar
02C4S is infamous around these parts
Try getting this connector. Just installed it last week in about 20 minutes and it works flawlessly.
www.iwirep.com
...Joel
Old Apr 2, 2011 | 01:22 PM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
order the cable...becker has it
Old Apr 2, 2011 | 02:17 PM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
I have the Becker cable for 4G iPod Touch/iPhone and I'm very happy with it. It's more expensive ($100 iirc) than the ones for earlier iPods. It uses the normal iPod connector, like the one you use to connect it to your computer, not RCA plugs.
Old Apr 2, 2011 | 04:21 PM
copper's Avatar
copper has a spectacular aura aboutcopper has a spectacular aura about
Old Apr 2, 2011 | 05:06 PM
wyovino's Avatar
That is not the same cable. That cable will not charge your iPod. Cheaper, yes...as useful, no.
Old Apr 2, 2011 | 05:51 PM
copper's Avatar
Isn't this the same wire that One of the other peps stated ?
I guess I looked wrong.
http://www.iwirep.com/products/iwirep-220-35mm
Old Apr 2, 2011 | 06:35 PM
wyovino's Avatar
Maybe it is, but I was talking about a cable for all iPods and iPhones, including the latest 4G devices. This is a single connection that plays through the radio and keeps the iPod charged. Here is my set up.
Old Apr 2, 2011 | 07:23 PM
02C4S's Avatar
The cable above is the iWireP cable. It works fine, but won't charge your phone or iPod while in use obviously since it uses the headphone jack. I'll have to look at for the Becker cable as I'd like to be able to have my phone charge while in use.
...Joel
Old Apr 2, 2011 | 08:53 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Step one ----junk the whole thing and start over. Becker sucks, BOSE sucks. Step two --- start with a decent aftermarket double din head unit which gives you a great IPOD interface, Voice Nav, blue tooth, back up cam, media port, DVD player etc Step three get a good seperate amp and new speakers.
Jerry rigging the stock systems is money down a well. Trust me, I bought the IPOD interface for the BOSE systems and it kinda sorta works when it wants to. Still no blue tooth and an outdated nav system that requires stupid expensive updated nav discs.
Old Apr 2, 2011 | 09:01 PM
wyovino's Avatar
I agree that if you want a Nav unit and something that doesn't look stock, go with a double-din unit. But if you just want to play your iPod through your existing system, go with the Becker cable. Mine works perfectly every time.
Old Apr 3, 2011 | 06:56 PM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
Does anyone know if the following will work to accomplish what the OP wants?
add these 2 together....pretty simple and affordable:
http://cgi.ebay.com/PORSCHE-INTERFAC...ht_3774wt_1141
http://cgi.ebay.com/iPod-iPhone-4-3G...ht_3046wt_1141
Old Apr 3, 2011 | 09:02 PM
wyovino's Avatar
It looks like it might work, but why would you want to build a Rube Goldberg system when a much more elegant solution exists?
Old Apr 4, 2011 | 01:14 PM
aerogt3's Avatar
aerogt3 is infamous around these partsaerogt3 is infamous around these parts
There aren't any solutions like this for a MOST bus car, or are there?
